I decided to install CUDA for computer vision projects.
Once installed, I tried to run the c++ code exemple on this page :https://devblogs.nvidia.com/even-easier-introduction-cuda/ unfortunately I got a core dumped error by running it. By using cuda-gdb I found out this error comes from this for loop :
// initialize x and y arrays on the host
for (int i = 0; i < N; i++) {
x[i] = 1.0f;
y[i] = 2.0f;
and returns
fatal: No CUDA capable device was found. (error code = CUDBG_ERROR_NO_DEVICE_AVAILABLE(0x27)
Also tried to run a simple “Hello World” code, but it didn’t print anything.
Now here are the details about my setup and how I installed CUDA:
I use ubuntu 18.04 LTS with an Asus S56C laptop
I have a GEFORCE 740M GPU
nvcc --version returns :
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Fri_Feb__8_19:08:17_PST_2019
Cuda compilation tools, release 10.1, V10.1.105
I have the NVIDIA 418 driver
I installed CUDA via the runfile (None of the others worked for me), the installation got completed with a few errors, and then I installed nvcc with apt-get. After trying to run the code, I uninstalled and reinstalled everything by following the installation guide.
I found out in the 4.5 section (https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-verifications) that the /dev/nvidia* files do not exist, and the given script returns this:
modprobe: ERROR: could not insert 'nvidia': Operation not permitted
even when I run it as a superuser. I have no problem with the post-installation actions though.
I posted the log files here : https://drive.google.com/open?id=1Qsg7EtDMuyOr39L51ZfDQReGaaE_O3As
Edit : Here are the errors in my cuda-installer.log anyway:
[INFO]: ERROR: The kernel module failed to load. Secure boot is enabled on this
[INFO]: system, so this is likely because it was not signed by a key that is
[INFO]: trusted by the kernel. Please try installing the driver again, and
[INFO]: sign the kernel module when prompted to do so.
[INFO]:
[INFO]:
[INFO]: ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most
[INFO]: frequently when this kernel module was built against the wrong or
[INFO]: improperly configured kernel sources, with a version of gcc that
[INFO]: differs from the one used to build the target kernel, or if another
[INFO]: driver, such as nouveau, is present and prevents the NVIDIA kernel
[INFO]: module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA
[INFO]: GPU installed in this system is supported by this NVIDIA Linux
[INFO]: graphics driver release.
[INFO]:
[INFO]: Please see the log entries 'Kernel module load error' and 'Kernel
[INFO]: messages' at the end of the file '/var/log/nvidia-installer.log' for
[INFO]: more information.
[INFO]:
[INFO]:
[INFO]: ERROR: Installation has failed. Please see the file
[INFO]: '/var/log/nvidia-installer.log' for details. You may find
[INFO]: suggestions on fixing installation problems in the README available
[INFO]: on the Linux driver download page at www.nvidia.com.
Thanks in advance to those who will help me, tell me if you need any more detail.
