I get bellow error when I try to execute a cuda based program in ubuntu 16.04. It successfully compiles and when tried to execute following error is generated.
“cudaSetDevice failed! Do you have a CUDA-capable GPU installed?”
Below is the screen shot of “nvidia-smi” command execution.
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 GeForce 940MX Off | 00000000:01:00.0 Off | N/A |
| N/A 51C P0 N/A / N/A | 164MiB / 2004MiB | 4% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1144 G /usr/lib/xorg/Xorg 124MiB |
| 0 2104 G compiz 37MiB |
Below is the result after execution of “nvcc --version”
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
I have been trying to resolve this re-installing both cuda and drivers. Nothing seems to work.
Does any one know a way to solve this problem.
