spec:
cpu - intel® core™ 2 Duo 2.80 GHz.
ram - 2 GB
system type - 64-bit Operating System
nvidia 9800 GT
=> I download 1. CUDA Driver 2. CUDA Toolkit 3. CUDA SDK code samples (Operating System: Windows XP 64-bit)
I can’t install CUDA Driver?
Thank.
It would be really helpful if you display the error you get !!!
if zou are talking about driver 181.20 this can be helpful
I had the same problems
edited nv4_disp.inf to add the following lines -
in section
[NVIDIA.Mfg]
%NVIDIA_G84.DEV_040C.1% = nv4_WSApps_G8x, PCI\VEN_10DE&DEV_040C
and
; Localizable Strings
NVIDIA_G84.DEV_040C.1 = “NVIDIA Quadro FX 570M”
the re-ran setup
i hope it helps :)
