Hi everyone!
I wanted to share my experience running GLM-4.7-FP8 (355B parameters, 32B active) on a 4-node DGX Spark cluster. After some trial and error, I got it working smoothly with SGLang and EAGLE speculative decoding.
The Challenge
When I first tried to run GLM-4.7-FP8 on DGX Spark with SGLang, I hit this error:
OutOfResources: out of resource: shared memory
Required: 147456, Hardware limit: 101376
The GB10’s shared memory limit (101,376 bytes) is the same as the RTX 4090. SGLang’s default MoE kernel settings exceed this limit.
The Solution
I ran SGLang’s MoE kernel tuning script to generate optimized configurations specifically for the GB10. The tuning took about 9 hours across 4 nodes, but the resulting configs work perfectly.
Key insight: You must use lmsysorg/sglang:spark container for GB10 - the standard :latest does NOT work (sgl-kernel not compiled for sm_121).
I’ve also published a pre-built Docker image with all configs and patches applied:
docker pull ghcr.io/btankut/sglang-spark-glm47:latest
Results
With optimized configs + EAGLE speculative decoding:
| Metric | Value |
| Throughput | 20-27 tok/s |
| Context Window | 202,752 tokens |
| GPU Memory | ~82 GB per node |
| GPU Utilization | 94-95% |
Hardware Setup
- 4x DGX Spark (GB10, 128GB each)
- 200Gbps RoCE network (dedicated fabric)
- Container:
lmsysorg/sglang:sparkorghcr.io/btankut/sglang-spark-glm47:latest
Network Architecture (Important!)
For multi-node inference, I recommend using a dedicated fabric network for NCCL traffic:
│ 200Gbps Fabric Network │
│ (NCCL/RDMA Traffic Only) │
│ │ Node 0 │ │ Node 1 │ │ Node 2 │ │ Node 3 │ │
│ │ .101.11 │ │ .101.12 │ │ .101.13 │ │ .101.14 │ │
│ │ (Head) │ │ (Worker) │ │ (Worker) │ │ (Worker) │ │
This separates high-bandwidth GPU-to-GPU communication from regular LAN traffic.
Quick Start
# Option A: Use pre-built image (recommended)
# Option B: Use base spark image + manual config setup
# See GitHub repo for config installation steps
# Start container on each node
docker run -d --name sglang_node \
--network host --ipc=host --gpus all \
--ulimit memlock=-1 --ulimit stack=67108864 \
--device=/dev/infiniband/uverbs0 \
--device=/dev/infiniband/uverbs1 \
--device=/dev/infiniband/uverbs2 \
--device=/dev/infiniband/uverbs3 \
-v ~/.cache/huggingface:/root/.cache/huggingface \
ghcr.io/btankut/sglang-spark-glm47:latest sleep infinity
# Launch on head node (rank 0)
docker exec -d sglang_node bash -c '
export NCCL_SOCKET_IFNAME=enP2p1s0f1np1
export GLOO_SOCKET_IFNAME=enP2p1s0f1np1
export NCCL_IB_HCA=mlx5_1
export VLLM_HOST_IP=192.168.101.11
python3 -m sglang.launch_server \
--model-path zai-org/GLM-4.7-FP8 \
--tp 4 --nnodes 4 --node-rank 0 \
--dist-init-addr 192.168.101.11:50000 \
--dist-timeout 600 \
--host 0.0.0.0 --port 30000 \
--trust-remote-code \
--tool-call-parser glm \
--reasoning-parser glm45 \
--speculative-algorithm EAGLE \
--speculative-num-steps 3 \
--speculative-num-draft-tokens 8 \
--speculative-eagle-topk 2 \
--context-length 202752 \
> /tmp/sglang.log 2>&1
# Similar for workers (change --node-rank and VLLM_HOST_IP)
Config Files & Full Instructions
I’ve uploaded everything to GitHub:
The repo includes:
- Dockerfile - Build your own optimized container
- Pre-built image -
ghcr.io/btankut/sglang-spark-glm47:latest - Pre-tuned MoE kernel configs for GB10
- Tool call parser patch for GLM-4.7
- Complete multi-node setup guide
- Step-by-step tuning guide (for other models)
Tips That Helped Me
- Use dedicated fabric network - Separating NCCL traffic from LAN improved stability
- Enable EAGLE speculative decoding - Noticeable throughput improvement
- Set
--dist-timeout 600- Prevents timeouts during model loading - Clean old processes -
pkill -9 -f sglangbefore restarting
Common Issues
| Problem | Solution |
| “Init torch distributed begin” hangs | Kill old sglang processes on all nodes |
| OutOfResources error | Ensure MoE configs are in Triton directory |
| Slow performance | Verify NCCL is using RoCE, not sockets |
Contributing
If you generate configs for other MoE models on GB10, please share them! It would be great to build a collection for the DGX Spark community.
Hope this helps someone! Happy to answer questions.
