Run SGLang in Spark
Run SGLang Spark
  1. Install uv
curl -LsSf https://astral.sh/uv/install.sh | sh
  1. Create environment
uv venv .sglang --python 3.12
source .sglang/bin/activate
sudo apt install python3-dev python3.12-dev
  1. Export variables
export TORCH_CUDA_ARCH_LIST=12.1a
export TRITON_PTXAS_PATH=/usr/local/cuda/bin/ptxas
export PATH=/usr/local/cuda/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH
  1. Install SGLang
uv pip install sgl-kernel --prerelease=allow --index-url https://docs.sglang.ai/whl/cu130/
uv pip install sglang --prerelease=allow
uv pip install --force-reinstall torch torchvision torchaudio triton --index-url https://download.pytorch.org/whl/cu130
uv pip install flashinfer-python
  1. Clean memory
sudo sysctl -w vm.drop_caches=3
  1. Run gptoss 120b nvfp4
mkdir -p ~/tiktoken_encodings
wget -O ~/tiktoken_encodings/o200k_base.tiktoken "https://openaipublic.blob.core.windows.net/encodings/o200k_base.tiktoken"
wget -O ~/tiktoken_encodings/cl100k_base.tiktoken "https://openaipublic.blob.core.windows.net/encodings/cl100k_base.tiktoken"
python3 -m sglang.launch_server --model-path openai/gpt-oss-120b --host 0.0.0.0 --port 30000 --reasoning-parser gpt-oss --tool-call-parser gpt-oss
If triton backend fails for you, delete triton_kernel path and compile/install from main.
SGLANG Released: cu130 kernels can be downloaded here https://github.com/sgl-project/whl/blob/gh-pages/cu130/sgl-kernel/index.html
@johnny_nv I was able to get it working with models like qwen and Nanonets, but I kept encountering this error with gpt-oss. Were you able to run gpt-oss-20/120b?
================================ SGLang  gpt-oss ===============================================
Scheduler hit an exception: Traceback (most recent call last):
  File "sglang_spark/sglang/python/sglang/srt/managers/scheduler.py", line 2753, in run_scheduler_process
    scheduler = Scheduler(
  File "sglang_spark/sglang/python/sglang/srt/managers/scheduler.py", line 311, in __init__
    self.tp_worker = TpModelWorker(
  File "sglang_spark/sglang/python/sglang/srt/managers/tp_worker.py", line 235, in __init__
    self._model_runner = ModelRunner(
  File "sglang_spark/sglang/python/sglang/srt/model_executor/model_runner.py", line 312, in __init__
    self.initialize(min_per_gpu_memory)
  File "sglang_spark/sglang/python/sglang/srt/model_executor/model_runner.py", line 384, in initialize
    self.load_model()
  File "sglang_spark/sglang/python/sglang/srt/model_executor/model_runner.py", line 739, in load_model
    self.model = get_model(
  File "sglang_spark/sglang/python/sglang/srt/model_loader/__init__.py", line 28, in get_model
    return loader.load_model(
  File "sglang_spark/sglang/python/sglang/srt/model_loader/loader.py", line 595, in load_model
    self.load_weights_and_postprocess(
  File "sglang_spark/sglang/python/sglang/srt/model_loader/loader.py", line 614, in load_weights_and_postprocess
    quant_method.process_weights_after_loading(module)
  File "sglang_spark/sglang/python/sglang/srt/layers/quantization/mxfp4.py", line 541, in process_weights_after_loading
    from triton_kernels.matmul_ogs import FlexCtx, PrecisionConfig
  File "sglang_spark/.sglang/lib/python3.12/site-packages/triton_kernels/matmul_ogs.py", line 15, in <module>
    from .matmul_ogs_details._matmul_ogs import _compute_writeback_idx
  File "sglang_spark/.sglang/lib/python3.12/site-packages/triton_kernels/matmul_ogs_details/_matmul_ogs.py", line 8, in <module>
    from triton_kernels.numerics_details.flexpoint import float_to_flex, load_scale
  File "sglang_spark/.sglang/lib/python3.12/site-packages/triton_kernels/numerics_details/flexpoint.py", line 55, in <module>
    @tl.constexpr_function
AttributeError: module 'triton.language' has no attribute 'constexpr_function'
Received sigquit from a child process. It usually means the child failed.
you have to uninstall triton_kernels.
in my case:
rm -rf /home/spark/ray_test/.venv/lib/python3.12/site-packages/triton_kernels
I did similar modifications from this: GitHub - yvbbrjdr/triton at spark
it should be fixed in main from triton.
@johnny_nv That was very helpful to solve triton_kernels issue, but I have new issue. I did a bit research, but I could not find a decent solution to fix the issue. If I downgrade transformers, I get triton language error. if I keep the transformer 4.57.1, I get this error
uv run python -m sglang.launch_server --model-path openai/gpt-oss-20b --host 0.0.0.0 --port 30000 --mem-fraction-static 0.8
sglang_spark/.sglang/lib/python3.12/site-packages/torch/cuda/__init__.py:283: UserWarning:
    Found GPU0 NVIDIA GB10 which is of cuda capability 12.1.
    Minimum and Maximum cuda capability supported by this version of PyTorch is
    (8.0) - (12.0)
  warnings.warn(
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "sglang_spark/sglang/python/sglang/launch_server.py", line 7, in <module>
    from sglang.srt.server_args import prepare_server_args
  File "sglang_spark/sglang/python/sglang/srt/server_args.py", line 61, in <module>
    from sglang.srt.utils.hf_transformers_utils import check_gguf_file, get_config
  File "sglang_spark/sglang/python/sglang/srt/utils/hf_transformers_utils.py", line 26, in <module>
    from transformers import (
  File "sglang_spark/.sglang/lib/python3.12/site-packages/transformers/utils/import_utils.py", line 2317, in __getattr__
    module = self._get_module(self._class_to_module[name])
  File "sglang_spark/.sglang/lib/python3.12/site-packages/transformers/utils/import_utils.py", line 2347, in _get_module
    raise e
  File "sglang_spark/.sglang/lib/python3.12/site-packages/transformers/utils/import_utils.py", line 2345, in _get_module
    return importlib.import_module("." + module_name, self.__name__)
  File "/home/.local/share/uv/python/cpython-3.12.6-linux-aarch64-gnu/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "sglang_spark/.sglang/lib/python3.12/site-packages/transformers/models/auto/tokenization_auto.py", line 40, in <module>
    from .auto_factory import _LazyAutoMapping
  File "sglang_spark/.sglang/lib/python3.12/site-packages/transformers/models/auto/auto_factory.py", line 43, in <module>
    from ...generation import GenerationMixin
ImportError: cannot import name 'GenerationMixin' from 'transformers.generation' (sglang_spark/.sglang/lib/python3.12/site-packages/transformers/generation/__init__.py). Did you mean: 'GenerationMode'?
uv cache clean
hello, I wonder how I can fix this problem
do I need to compile triton from this repository?
The results are impressive: around 70 tokens/s on GPT-OSS 20B and 50 tokens/s on GPT-OSS 120B, which is state-of-the-art so far
Well, that’s a bold claim, considering that llama.cpp gives you 60 tokens/s on gpt-oss-120b and takes only a fraction of time to start (even less with 6.17 kernel).
It’s literally a one liner on the terminal.. I have not played llama.cpp yet. I’m a little iffy on making any major system changes on dgx spark. Would rather run llama.cpp in dockers but haven’t able to find one yet. I may make my own image.
You don’t need to make any major system changes to run llama.cpp. Dead simple to set up:
Install development tools:
sudo apt install clang cmake libcurl4-openssl-dev
Checkout llama.cpp
git clone https://github.com/ggml-org/llama.cpp.git
cd llama.cpp
Build:
cmake -B build -DGGML_CUDA=ON -DGGML_CURL=ON
cmake --build build --config Release -j 20
Then run, e.g.:
build/bin/llama-server -hf ggml-org/gpt-oss-120b-GGUF -fa 1 -ngl 999 -ub 2048 -b 2048 --jinja
My main problem with llama.cpp is the fact it it’s focused on single user, non-parallel requests.
Yes, it’s not designed for high concurrency, but it can handle parallel requests, you just need to specify -np parameter setting the max number of requests it can handle in parallel. You can also enable unified kv cache (–kv-unified), so KV cache is shared across the requests vs. creating np*kv_cache buffer. It has continuous batching by default.
See docs for details: llama.cpp/tools/server at master · ggml-org/llama.cpp · GitHub
I don’t think anyone would be using Spark in high concurrency scenarios anyway.
Yes, you’re correct, not to use the spark in high concurrency, but use the Spark to design/test their solution for high concurrency scenarios.
hi bro
when i follow u step to install sglang,something hanppend.
then i use command like this to fix(Could NOT find NUMA (missing: NUMA_INCLUDE_DIRS NUMA_LIBRARIES)
):sudo apt-get install libnuma-dev
then another error,but i can’t understand where the problem is.so i upload the pic what i did,wait for help,thx!
it is not necessary to build anymore due that sglang distribute for cu130.
use triton 3.5.1 and flashinfer 0.5.2 that have some fixes for spark
Did they fix triton-kernels too? Do we need to install them?
Yes. You can test it. Same happened on gb300 in the past
should I install triton-kernels from the repo or they are uploaded to pypi?
Here is the fix: [chore] update torch version to 2.9 by FlamingoPg · Pull Request #12969 · sgl-project/sglang · GitHub
