Running separate models for each stream in parallel in DeepStream
T4
• DeepStream Version
5.0
NA
• TensorRT Version
7.0.0.11
440.64.00
I have a single DeepStream pipeline processing multiple streams. Say there are 8 streams and each of them has its own customized NN model. How can I run these in parallel?
Option 1: Create a DeepStream pipeline with 8 separate nvstreammux and 8 separate nvinfer modules. Connect each stream to its own nvstreammux.
Option 2: Somehow use triton server to do this.
Option 3: Run 8 separate DeepStream pipelines.
Which of the above are workable? Which is the best option? Are there any examples which demonstrate this separate-NN-models use case?
i work with options 3, and use containers
Option 4: Multi-camera Jetson TX2 AI Media Server demo | NVIDIA GTC 2020 RidgeRun demo
Option 3 works
Thanks @PhongNT @rsc44 @Fiona.Chen .
