Same Source elements or Source pads in multiple pipelines
• Hardware Platform (Jetson / GPU) RTX 2060
• DeepStream Version 5.1
• TensorRT Version 7.1
• NVIDIA GPU Driver Version (valid for GPU only) 470
• Issue Type( questions, new requirements, bugs) Question
I have modified my deepstream application such that it generates multiple Pipelines which enables me to run different models in same application.
Here for each pipeline even if the source or input URI is the same I am duplicating it in each pipeline, Is there a way to share same source element with all the pipelines so that I can save some pre processing/ loading time or memory?
Can you use tee plugin in your pipeline?
