hi i am working on a project and was wondering if it is possible to insert a buzzer or led at the i/o pin to light up or buzz when it detects an object i.e weapon etc. and if so do you have any suggestion how may i do that?
hello reynard.ting,
you may use the GPIOs to have implementation.
please refer to NVIDIA Jetson Nano J41 Header Pinout for the pin outs.
you might also refer to similar discussion threads Topic 1029697 and Topic 1030443 for reference.
thanks
Related topics
| Using GPIO pins on my own object detection program | 3 | 1311 | May 27, 2021 | |
| How to use a buzzer on the GPIO pins of Jetson Nano? | 1 | 756 | July 13, 2023 | |
| How to raise an alarm from a GPIO pin of Jetson Nano once an object is detected? | 5 | 1599 | May 27, 2021 | |
| How use GPIO on Jetson Nano to trigger external actuators or LEDs when an object is detected? | 4 | 1508 | August 27, 2020 | |
| jeston nano how to be comunication with stm32 | 1 | 1608 | June 26, 2019 | |
| Jetson Nano Fast GPIO C++ Example with Direct Register Access | 18 | 10463 | June 19, 2021 | |
| Jetson Nano GPIO example problem | 30 | 22908 | September 23, 2021 | |
| How to use ultrasonioc sensor on jetson nano ? | 1 | 2056 | May 20, 2019 | |
| Jetson nano gpio enable and interrupt enable | 1 | 596 | March 22, 2021 | |
| Jetson Inference Jetson.GPIO does not work | 4 | 1258 | August 18, 2021 |
