For building Torch-Tensorrt for python, it mentions only two jetpack support in setup.py file i.e., 4.6 or 4.5. But as per this link, ORIN is not among listed device for Jetpack version lower than 5.0 DP. Is there a way to run Torch-Tensorrt on ORIN. I have tried compiling with Jetpack-5.0DP, it compiles fine but torch_tensorrt doesn’t have have any attributes on import.
Related topics
| How can I install torch_tensorrt on the Orin | 6 | 2220 | September 13, 2023 | |
| Unable to compile torch_tensorrt on Orin | 3 | 767 | June 14, 2022 | |
| How to install torch_tensorrt | 2 | 418 | August 20, 2025 | |
| How to Install Torch_TensorRT for Jetson AGX ORIN | 4 | 586 | June 5, 2025 | |
| Jetson Orin Nano Developer Kit, Jetpack, Cuda, Tensorflow with GPU and TensorRT | 15 | 4327 | September 28, 2023 | |
| Jetson Orin, TensorRT, CUDA 11.8 for PyTorch 2.0.0 | 4 | 1997 | November 28, 2023 | |
| How to install PyTorch on Jetson Orin? | 2 | 431 | August 12, 2025 | |
| Unable to install pytorch and torchvision on jetson orin | 14 | 1547 | March 19, 2025 | |
| TensorRT doesn't found in Jetpack 5.1.2 | 2 | 1105 | August 30, 2023 | |
| Compatible pytorch version for the jetson orin with jetpack 6.2 | 11 | 4234 | March 20, 2025 |
