Unable to compile torch_tensorrt on Orin
I am receiving compiling error when trying to build troch_trensorrt on the new Orin. I am guessing there might be some dependency issue? Has anyone experienced this before?
Could you share the source/command you used for compiling with us first?
I followed this GitHub repo: GitHub - pytorch/TensorRT: PyTorch/TorchScript/FX compiler for NVIDIA GPUs using TensorRT.
With command: bazel build //:libtorchtrt --compilation_mode opt
It seems that there are some dependency issues with JP5.0? Is there any chance that we can downgrade some software like CUDA or TensoRT?
Only JetPack 5.0.x supports Orin.
Instead of compiling from the source, we also have some prebuilt PyTorch packages for Jetson users.
Could you check if the package can meet your requirement?
https://developer.download.nvidia.com/compute/redist/jp/v50/pytorch/
