running trt.create_inference_graph causes system lockup and kernel restart
Provide details on the platforms you are using:
OS : Ubuntu 18.04
GPU : GTX 1080ti
nvidia driver version : 390.87
CUDA version : 9.0
CUDNN version : 7.3.1
Python version : 2.7.15rc1
Tensorflow version : tf-gpu 1.10.0
TensorRT version : 5.0.2.6
IDE: Spyder
Describe the problem:
I have trained the DGCNN classifier model (https://github.com/WangYueFt/dgcnn) and verified the tf graph is successfully producing inferences. I have frozen the graph and saved it as a .pb binary. Upon running trt.create_inference_graph it complains that is was compiled against TRT 3.0.4 but loaded TRT 4.0.1 and that it may not work, though only TRT 5 is installed, included in PATH and LD_LIBRARY_PATH, and pip installed. After this, my machine locks up. Eventually IPython console blacks out and the python kernel restarts. My code for freezing and converting to TRT is included below. Unfortunately I can’t include the exact console output, because of the hanging issue described above, but the above summary captures it all.
My first question is, what are the actual requirements for compatibility across cuda toolkit, tensorflow, tensorrt, and OS? There is conflicting guidance out there. I am following the compatibility matrix in “Accelerating Inference In TensorFlow With TensorRT User Guide”, though I can’t find a download for TRT 5.0.0rc in particular.
def save_trt_graph(export_dir):
tf.reset_default_graph()
G = tf.Graph()
with G.as_default():
    pointclouds_pl, labels_pl = MODEL.placeholder_inputs(1, NUM_POINT)
    is_training_pl = tf.placeholder(tf.bool, shape=())
    # simple model
    pred, end_points = MODEL.get_model(pointclouds_pl, is_training_pl)
    config = tf.ConfigProto(allow_soft_placement = True)
   # Create Session
    with tf.Session(graph=G, config=config) as sess:
        with G.device('gpu:0'):
            sess.run(tf.global_variables_initializer())
            # This one imports model from checkpoint metagraph
            saver = tf.train.import_meta_graph(MODEL_PATH+'.meta')
            # Restore variables from checkpoint.
            saver.restore(sess, MODEL_PATH)
            # fix nodes
            gd = sess.graph.as_graph_def()
            for node in gd.node:
                if node.op == 'RefSwitch':
                    node.op = 'Switch'
                    #for index in xrange(len(node.input)):
                    #    node.input[index] = node.input[index] + '/read'
                elif node.op == 'AssignSub':
                    node.op = 'Sub'
                    if 'use_locking' in node.attr: del node.attr['use_locking']
            log_string("\nModel restored.\n")
            frozen_graph = tf.graph_util.convert_variables_to_constants(
                    sess,
                    gd,
                    output_node_names=['fc3/output'])
            trt_output_graph_def = trt.create_inference_graph(
                    input_graph_def=frozen_graph,
                    outputs = ['fc3/output'],
                    max_batch_size=1,
                    max_workspace_size_bytes=1<<30,
                    precision_mode="FP32")
regarding TensorRT 5RC (release candidate), it has been replaced by TensorRT 5GA (General Availability). Please use it as the latest version. I also recommend using NVIDIA TensorRT container, which removes many of the dependency issues you may be seeing. It’s available here: https://www.nvidia.com/en-us/gpu-cloud/ the account is free.
