Greetings!
I am trying to run a TensorRT CUDA inference (onnx model) program compiled on x86_64 on Jetson Nano. The base idea comes to my mind is to use qemu-user to emulate the CPU part, and use cuda to run the inference.
What I have tried
I use chroot and qemu-user-static and can successfully run x86 compiled program on CPU.
Jetson Nano CUDA: 12.0
Container CUDA: 12.0
qemu-user: 6.12, compiled from source
docker command:
docker run -e DISPLAY=:0 --runtime=nvidia \
--platform=linux/amd64 --name=run2test \
-v ./qemu-6.2.0/build/qemu-x86_64:/usr/bin/qemu-x86_64-static \
-v /tmp/.X11-unix:/tmp/.X11-unix --privileged -it test:latest
I tried to install x86 cuda in the container, but when the program runs through the cuda part, it prompts "CUDA failure 100: no CUDA-capable device is detected ":
/workspace/onnx/onnxruntime/onnxruntime/core/providers/cuda/cuda_call.cc:122
bool onnxruntime::CudaCall(ERRTYPE, const char*, const char*, ERRTYPE, const
char*) [with ERRTYPE = cudaError; bool THRW = true]
/workspace/onnx/onnxruntime/onnxruntime/core/providers/cuda/cuda_call.cc:116
char*) [with ERRTYPE = cudaError; bool THRW = true] CUDA failure 100: no CUDA-
capable device is detected ; GPU=0 ; hostname=435555c1560b ; expr=cudaSetDevice(device_id_);
Is there any trick or idea that can be helpful to this? The program is closed-source and thus cannot be cross-compiled. Deep thanks!
