kavya
February 7, 2008, 1:38pm
1
I am getting a runtime error from the following function:
(in cuda_runtime.h)
template<class T, int dim, enum cudaTextureReadMode readMode>
static inline host cudaError_t cudaBindTextureToArray(
const struct texture<T, dim, readMode> &tex,
const struct cudaArray *array
struct cudaChannelFormatDesc desc;
cudaError_t err = cudaGetChannelDesc(&desc, array);
return err == cudaSuccess ? cudaBindTextureToArray(tex, array, desc) : err;
my code looks like this:
texture<float, 2, cudaReadModeElementType> texRef;(declared as a global)
cudaArray* cuArray;
cudaMallocArray(&cuArray, &texRef.channelDesc, width, height);
cudaBindTextureToArray (texRef, originalImage);
My block dimension is (16 x 16),
grid dimension is ( width/16, height/16)
I do not get this error when width = height = 8192, but i get it when i increase the width and height to 16384
Can someone please tell me what could be the problem?
(in cuda_runtime.h)
cudaArray* cuArray;
[snapback]322097[/snapback]
Try to compile with the -cubin option and look at the .cubin file. I think you are using to much registers, because your talking about 8192 border. take a look at the programming guide Appendix A.1
Cite from CUDA Programming guide Section A.1:
For a texture reference bound to linear memory, the maximum width is 2^27
8192 is 2^13 so 81928192 is 2^26. But 16384 is 2^14 and so 16384 16384 is 2^28.
kavya
February 7, 2008, 6:24pm
4
[snapback]322127[/snapback]
Section A.1 of programming guide says:
for a texture reference bound to a 2D CUDA array, the max width is 2^16 and max height is 2^15
I am using 2D CUDA arrays, not linear memory for texturing. So, i am not exceeding the bounds.
1638416384 4 / 1024^3 = 1. You are allocating 1GiB of memory. You don’t mention your hardware, but this can only be possible if you have Tesla or a Quadro.
kavya
February 11, 2008, 8:49am
6
[snapback]322987[/snapback]
You are right, I’m using GEForce 8800 GTS which has only .67 GB of memory.
Thank You Mr. Anderson, now I atleast know that there is nothing wrong with my programming :)
