RUNTIME_EXCEPTION : Non-zero status code returned while running Conv node
Hey everyone,
I’m using CUDA Toolkit version 11.8 and cuDNN version 8.9.6 with my RTX 4070 GPU.
I am getting this error that I haven’t been able to solve:
onnxruntime.capi.onnxruntime_pybind11_state.RuntimeException: [ONNXRuntimeError] : 6 : RUNTIME_EXCEPTION : Non-zero status code returned while running Conv node. Name:‘Conv_242’ Status Message: D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_call.cc:121 onnxruntime::CudaCall D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_call.cc:114 onnxruntime::CudaCall CUDA failure 2: out of memory ; GPU=0 ; hostname=LAPTOP-61H6U28U ; file=D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_allocator.cc ; line=48 ; expr=cudaMalloc((void*)&p, size);
Any hints as to why this might be?
Below the full error log:
File “C:\Users\User\Desktop\workspaces\roop\run.py”, line 6, in
** core.run()**
** File “C:\Users\User\Desktop\workspaces\roop\roop\core.py”, line 217, in run**
** start()**
** File “C:\Users\User\Desktop\workspaces\roop\roop\core.py”, line 169, in start**
** frame_processor.process_video(roop.globals.source_path, temp_frame_paths)**
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\face_swapper.py”, line 100, in process_video**
** roop.processors.frame.core.process_video(source_path, temp_frame_paths, process_frames)**
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\core.py”, line 79, in process_video**
** multi_process_frame(source_path, frame_paths, process_frames, lambda: update_progress(progress))**
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\core.py”, line 57, in multi_process_frame**
** future.result()**
** File “C:\Program Files\Python39\lib\concurrent\futures_base.py”, line 439, in result**
** return self.__get_result()**
** File “C:\Program Files\Python39\lib\concurrent\futures_base.py”, line 391, in __get_result**
** raise self._exception**
** File “C:\Program Files\Python39\lib\concurrent\futures\thread.py”, line 58, in run**
** result = self.fn(self.args, self.kwargs)
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\face_swapper.py”, line 81, in process_frames
** result = process_frame(source_face, reference_face, temp_frame)**
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\face_swapper.py”, line 72, in process_frame**
** temp_frame = swap_face(source_face, target_face, temp_frame)**
** File “C:\Users\User\Desktop\workspaces\roop\roop\processors\frame\face_swapper.py”, line 60, in swap_face**
** return get_face_swapper().get(temp_frame, target_face, source_face, paste_back=True)**
** File “C:\Users\User\AppData\Roaming\Python\Python39\site-packages\insightface\model_zoo\inswapper.py”, line 53, in get**
** pred = self.session.run(self.output_names, {self.input_names[0]: blob, self.input_names[1]: latent})[0]**
** File “C:\Users\User\AppData\Roaming\Python\Python39\site-packages\onnxruntime\capi\onnxruntime_inference_collection.py”, line 217, in run**
** return self._sess.run(output_names, input_feed, run_options)**
onnxruntime.capi.onnxruntime_pybind11_state.RuntimeException: [ONNXRuntimeError] : 6 : RUNTIME_EXCEPTION : Non-zero status code returned while running Conv node. Name:‘Conv_242’ Status Message: D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_call.cc:121 onnxruntime::CudaCall D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_call.cc:114 onnxruntime::CudaCall CUDA failure 2: out of memory ; GPU=0 ; hostname=LAPTOP-61H6U28U ; file=D:\a_work\1\s\onnxruntime\core\providers\cuda\cuda_allocator.cc ; line=48 ; expr=cudaMalloc((void)&p, size);**
