runtime problems: call to cuMemAlloc returned error 700
Hello Everybody,
I am trying to accelerate a simple fortran code (see below) and I get problems in execution. Here is the code:
IMPLICIT NONE
INTEGER, PARAMETER :: wp=KIND(1.0d0)
integer:: plpnl=50
integer:: pltnl=50
integer:: ipenl=1100
integer:: nwi=64
integer:: ipbnl=1
integer:: plnl=2300
integer:: ii,jj
real(wp):: rand
integer :: ip,ip1
real(wp),dimension(:,:),allocatable :: integrand_prep_J
real(wp),dimension(:,:),allocatable :: real_integrand_prep_J
real(wp),dimension(:,:),allocatable :: imag_integrand_prep_J
real(wp),dimension(:,:,:),allocatable :: integrand_prep_J_ip
real(wp),dimension(:,:,:),allocatable :: real_integrand_prep_J_ip
real(wp),dimension(:,:,:),allocatable :: imag_integrand_prep_J_ip
REAL(wp) :: Coef
integer :: i_theC,i_phiC
REAL(wp),DIMENSION(3,3) :: matrice,matrice1
REAL(wp),DIMENSION(:), allocatable  :: wi
REAL(wp),DIMENSION(:,:), allocatable  :: rprime_iwi1
REAL(wp),DIMENSION(:,:,:), allocatable  :: C_grid_rhat
REAL(wp),DIMENSION(:,:,:,:), allocatable  :: Mat1ij
REAL(wp),DIMENSION(:,:,:,:), allocatable  :: Mat2ij
real(wp),DIMENSION(3) :: integrand_J
INTEGER :: i_wi
real(wp) :: integrand_th,integrand_ph
real(wp),DIMENSION(3) :: integrand_prep_J_iwi
real(wp) :: E_theC,E_phiC,ctmp(3)
real(wp) :: rE_theC,rE_phiC
real(wp) :: deph_transl
REAL(wp) :: scalC
real(wp) :: rtmp(3),itmp(3),Ru1,Ru2,Ru3,Iu1,Iu2,Iu3
real(wp) :: rtmp1(3),itmp1(3)
real(wp),dimension(:,:,:),allocatable :: Uc
      ALLOCATE(wi(nwi))
      ALLOCATE(rprime_iwi1(3,nwi))
      ALLOCATE(integrand_prep_J(3,nwi))
      ALLOCATE(real_integrand_prep_J(3,nwi))
      ALLOCATE(imag_integrand_prep_J(3,nwi))
      ALLOCATE(integrand_prep_J_ip(3,nwi,ipbnl:ipeNL))
      ALLOCATE(real_integrand_prep_J_ip(3,nwi,ipbnl:ipeNL))
      ALLOCATE(imag_integrand_prep_J_ip(3,nwi,ipbnl:ipeNL))
      ALLOCATE(Uc(PLpNL,PLtNL,ipbnl:ipeNL))
      ALLOCATE(C_grid_rhat(3,PLpNL,PLtNL))
      ALLOCATE(Mat1ij(PLpNL,PLtNL,3,3))
      ALLOCATE(Mat2ij(PLpNL,PLtNL,3,3))
        do ip=ipbnl,ipenl
        do i_wi=1,nwi
        do ii=1,3
        integrand_prep_J(ii,i_wi)=cmplx(rand(),rand(),wp)
        integrand_prep_J_ip(ii,i_wi,ip)=integrand_prep_J(ii,i_wi)
        real_integrand_prep_J_ip(ii,i_wi,ip)=real(integrand_prep_J_ip(ii,i_wi,ip))
        enddo
        enddo
        enddo
        do i_phiC=1,PLpNL
        do i_theC=1,PLtNL
        do jj=1,3
        C_grid_rhat(jj,i_phiC,i_theC)=rand()
        do ii=1,3
        Mat1ij(i_phiC,i_theC,ii,jj)=rand()
        Mat2ij(i_phiC,i_theC,ii,jj)=rand()
        enddo
        enddo
        enddo
        enddo
        do i_wi=1,nwi
        do ii=1,3
        rprime_iwi1(ii,i_wi)=-1+rand()
        enddo
        enddo
!$acc kernels loop private(ip,real_integrand_prep_J,imag_integrand_prep_J)
  do 10 ip=ipbnl,ipenl
!$acc do private(i_phic)
  do 11 i_phiC=1,PLpNL
!$acc do private(matrice,i_theC,e_thec,e_phic,rtmp1,itmp1)
  do 12 i_theC=1,PLtNL
   matrice(:,:) =  Mat2ij(i_phiC,i_theC,:,:)
        re_thec=0._wp
        re_phic=0._wp
!$acc do private(rtmp,itmp,i_wi,ru1,iu1,ru2,iu2,ru3,iu3,scalc,integrand_j)
  do i_wi=1,nwi
    Rtmp(:)=real_integrand_prep_J_ip(:,i_wi,ip)
    integrand_J(1)=matrice(1,1)*Rtmp(1) + matrice(1,2)*Rtmp(2) + matrice(1,3)*Rtmp(3)
    integrand_J(2)=matrice(2,1)*Rtmp(1) + matrice(2,2)*Rtmp(2) + matrice(2,3)*Rtmp(3)
    scalC=      C_grid_rhat(1,i_phiC,i_theC)*rprime_iwi1(1,i_wi)
    scalC=scalC+C_grid_rhat(2,i_phiC,i_theC)*rprime_iwi1(2,i_wi)
    scalC=scalC+C_grid_rhat(3,i_phiC,i_theC)*rprime_iwi1(3,i_wi)
    integrand_th = integrand_J(1)*cos(scalc)
    integrand_ph = integrand_J(2)*cos(scalc)
    rE_theC = rE_theC + integrand_th*wi(i_wi)
    rE_phiC = rE_phiC + integrand_ph*wi(i_wi)
  end do
        matrice =  Mat1ij(i_phiC,i_theC,:,:)
        rtmp1(1)=re_thec
        rtmp1(2)=re_phic
    Uc(i_phiC,i_theC,ip)=matrice(1,1)*re_thec + matrice(1,2)*re_phic
  12 continue
  11 continue
  10 continue
END
I compile it with:
pgf90 -acc -Minfo=accel simple.f90
and when I run:
./a.out
call to cuMemAlloc returned error 700: Illegal address during kernel execution
It seems that the most inner loop causes the problems, but I don’t know how to fix it. Could someone guide me how to do it?
Many thanks,
Barak
Hi Barak,
How about something like the following. Privatizing arrays should be avoided if possible since every thread will get there own copy. Not only does this waste a lot of memory, the memory wont be accessed contiguously and the equivalent scalar variables most likely could then be put in a register.
 use iso_c_binding
 IMPLICIT NONE
 interface
   real(c_double) function rand () bind(C)
      use iso_c_binding
   end function rand
 end interface
 integer:: plpnl=50
 integer:: pltnl=50
 integer:: nwi=64
 integer:: ipbnl=1
 integer:: plnl=2300
 integer:: ii,jj
 integer :: ip,ip1
 REAL(wp) :: Coef
 real(wp) :: integrand_J1, integrand_J2
 INTEGER :: i_wi
 REAL(wp) :: scalC
 real(wp) :: rtmp1,rtmp2,rtmp3,itmp(3),Ru1,Ru2,Ru3,Iu1,Iu2,Iu3
 real(wp) :: rtmp11,rtmp12,rtmp13,itmp1(3)
       ALLOCATE(wi(nwi))
         do ip=ipbnl,ipenl
         do i_wi=1,nwi
         do ii=1,3
p))
         enddo
         enddo
         enddo
         do i_phiC=1,PLpNL
         do i_theC=1,PLtNL
         do jj=1,3
         do ii=1,3
         enddo
         enddo
         enddo
         enddo
         do i_wi=1,nwi
         do ii=1,3
         enddo
         enddo
 !$acc kernels loop  collapse(3) gang
         re_thec=0._wp
         re_phic=0._wp
  !$acc loop vector
   do i_wi=1,nwi
     Rtmp1=real_integrand_prep_J_ip(1,i_wi,ip)
     Rtmp2=real_integrand_prep_J_ip(2,i_wi,ip)
     Rtmp3=real_integrand_prep_J_ip(3,i_wi,ip)
     integrand_J1=Mat2ij(i_phiC,i_theC,1,1)*Rtmp1 + Mat2ij(i_phiC,i_theC,1,2)*Rt
mp2 + Mat2ij(i_phiC,i_theC,1,3)*Rtmp3
     integrand_J2=Mat2ij(i_phiC,i_theC,2,1)*Rtmp1 + Mat2ij(i_phiC,i_theC,2,2)*Rt
mp2 + Mat2ij(i_phiC,i_theC,2,3)*Rtmp3
     integrand_th = integrand_J1*cos(scalc)
     integrand_ph = integrand_J2*cos(scalc)
   end do
         !rtmp11=re_thec
         !rtmp12=re_phic
     Uc(i_phiC,i_theC,ip)=Mat2ij(i_phiC,i_theC,1,1)*re_thec + Mat2ij(i_phiC,i_theC,1,2)*re_phic
   12 continue
   11 continue
   10 continue
  print *, Uc(1,1,1)
 END
  • Mat
Hello Mat,
Thanks very much. It seems that your solution works perfectly. I think that I understand better the point of nested loops.
Barak
I implemened Mat’s suggestions and here is the current form of the code:
use iso_c_binding
 IMPLICIT NONE
 interface
      use iso_c_binding
   end function rand
 end interface
     !use dflib
     !use dfport
     !use accel_lib
     !use openacc
integer:: plpnl=41
integer:: pltnl=23
integer:: ipenl=21845
integer:: nwi=64
integer:: ipbnl=5462
integer:: plnl=943
integer:: ii,jj
integer :: ip,ip1
integer :: io
COMPLEX(wp),dimension(:,:),allocatable :: integrand_prep_J
COMPLEX(wp),dimension(:,:,:),allocatable :: integrand_prep_J_ip
REAL(wp) :: Coef
REAL(wp),DIMENSION(:,:,:,:), allocatable  :: M12_surf_sph_obs
REAL(wp),DIMENSION(:,:,:,:), allocatable  :: M12_sph_obs_obs
INTEGER :: i_wi
COMPLEX(wp) :: integrand_th,integrand_ph
COMPLEX(wp),DIMENSION(3) :: integrand_prep_J_iwi
real(wp) :: RE_theC,RE_phiC,ie_thec,ie_phic
COMPLEX(wp) :: deph_transl
REAL(wp) :: scalC
real(wp) :: Ru1,Ru2,Ru3,Iu1,Iu2,Iu3
real(wp) :: rtmp1,itmp1
real(wp) :: rtmp2,itmp2
real(wp) :: rtmp3,itmp3
COMPLEX(wp),dimension(:,:,:,:),allocatable :: Uc
integer :: c0, c1, c2, c3
real :: cgpu,  chost
real(wp) ::    r_deph_transl, i_deph_transl
      ALLOCATE(wi(nwi))
      ALLOCATE(Uc(3,ipbnl:ipeNL,PLpNL,PLtNL))
      ALLOCATE(M12_surf_sph_obs(PLpNL,PLtNL,3,3))
      ALLOCATE(M12_sph_obs_obs(PLpNL,PLtNL,3,3))
        print*,' memory of uc=',2*3*(ipeNL-ipbnl+1)*PLpNL*PLtNl
        print*,' memory of m12=',3*3*PLpNL*PLtNl
        print*,' memory of M12_sph_obs_obs=',PLpNL*PLtNL*3*3*2
        do ip=ipbnl,ipenl
        do i_wi=1,nwi
        do ii=1,3
        imag_integrand_prep_J_ip(ii,i_wi,ip)=imag(integrand_prep_J_ip(ii,i_wi,ip))
        enddo
        enddo
        enddo
        do i_phiC=1,PLpNL
        do i_theC=1,PLtNL
        do jj=1,3
        do ii=1,3
        M12_surf_sph_obs(i_phiC,i_theC,ii,jj)=rand()
        M12_sph_obs_obs(i_phiC,i_theC,ii,jj)=rand()
        enddo
        enddo
        enddo
        enddo
        do i_wi=1,nwi
        do ii=1,3
        enddo
        enddo
        call system_clock( count=c1 )
        re_thec=0._wp
        ie_thec=0._wp
        re_phic=0._wp
        ie_phic=0._wp
!$acc loop vector
  do i_wi=1,nwi
   itmp1=imag_integrand_prep_J_ip(1,i_wi,ip)
   itmp2=imag_integrand_prep_J_ip(2,i_wi,ip)
   itmp3=imag_integrand_prep_J_ip(3,i_wi,ip)
    Ru1=M12_surf_sph_obs(i_phiC,i_theC,1,1)*Rtmp1 + M12_surf_sph_obs(i_phiC,i_theC,1,2)*Rtmp2 + M12_surf_sph_obs(i_phiC,i_theC,1,3)*Rtmp3
    Iu1=M12_surf_sph_obs(i_phiC,i_theC,1,1)*Itmp1 + M12_surf_sph_obs(i_phiC,i_theC,1,2)*Itmp2 + M12_surf_sph_obs(i_phiC,i_theC,1,3)*Itmp3
    Ru2=M12_surf_sph_obs(i_phiC,i_theC,2,1)*Rtmp1 + M12_surf_sph_obs(i_phiC,i_theC,2,2)*Rtmp2 + M12_surf_sph_obs(i_phiC,i_theC,2,3)*Rtmp3
    Iu2=M12_surf_sph_obs(i_phiC,i_theC,2,1)*Itmp1 + M12_surf_sph_obs(i_phiC,i_theC,2,2)*Itmp2 + M12_surf_sph_obs(i_phiC,i_theC,2,3)*Itmp3
    Ru3=M12_surf_sph_obs(i_phiC,i_theC,3,1)*Rtmp1 + M12_surf_sph_obs(i_phiC,i_theC,3,2)*Rtmp2 + M12_surf_sph_obs(i_phiC,i_theC,3,3)*Rtmp3
    Iu3=M12_surf_sph_obs(i_phiC,i_theC,3,1)*Itmp1 + M12_surf_sph_obs(i_phiC,i_theC,3,2)*Itmp2 + M12_surf_sph_obs(i_phiC,i_theC,3,3)*Itmp3
    r_deph_transl=cos(scalc)
    i_deph_transl=sin(scalc)
    re_thec=re_thec+(ru1*r_deph_transl-iu1*i_deph_transl)*wi(i_wi)
    ie_thec=ie_thec+(r_deph_transl*iu1+ru1*i_deph_transl)*wi(i_wi)
    re_phic=re_phic+(ru2*r_deph_transl-iu2*i_deph_transl)*wi(i_wi)
    ie_phic=ie_phic+(r_deph_transl*iu2+ru2*i_deph_transl)*wi(i_wi)
  end do
    Ru1=M12_sph_obs_obs(i_phiC,i_theC,1,1)*re_thec + M12_sph_obs_obs(i_phiC,i_theC,1,2)*Re_phic
    Iu1=M12_sph_obs_obs(i_phiC,i_theC,1,1)*Ie_thec + M12_sph_obs_obs(i_phiC,i_theC,1,2)*Ie_phic
    Ru2=M12_sph_obs_obs(i_phiC,i_theC,2,1)*re_thec + M12_sph_obs_obs(i_phiC,i_theC,2,2)*re_phic
    Iu2=M12_sph_obs_obs(i_phiC,i_theC,2,1)*ie_thec + M12_sph_obs_obs(i_phiC,i_theC,2,2)*ie_phic
    Ru3=M12_sph_obs_obs(i_phiC,i_theC,3,1)*re_thec + M12_sph_obs_obs(i_phiC,i_theC,3,2)*re_phic
    Iu3=M12_sph_obs_obs(i_phiC,i_theC,3,1)*ie_thec + M12_sph_obs_obs(i_phiC,i_theC,3,2)*ie_phic
    Uc(1,ip,i_phiC,i_theC) = cmplx(Ru1,Iu1,wp)
    Uc(2,ip,i_phiC,i_theC) = cmplx(Ru2,Iu2,wp)
    Uc(3,ip,i_phiC,i_theC) = cmplx(Ru3,Iu3,wp)
  12 continue
  11 continue
  10 continue
 call system_clock( count=c2 )
        !print*, Uc(1,1,1,1)
cgpu = (c2 - c1)/1e6
        print*,cgpu
END
On my GPU (GTX 480) I get an acceleration of about 50 (with i7 processor).
Is it reasonable? how can I accelerate the code even more?
Thanks,
Barak
50 what? Seconds?
There’s many factors which determine what you should expect. A lot is based on what you’re comparing to (serial, OpenMP, etc.), the problem size (big problems tend to see more speed-up), the algorithm used.
General rule is that 4-5x speed-up is good, but a 1.5x speed-up for a program that takes days to run is still a huge savings. Though, it’s up to you to determine at what point is “good enough”.
  • Mat
