I have the following fortran90 code which I would like to accelerate using pgfortran:
IMPLICIT NONE
INTEGER, PARAMETER :: wp=KIND(1.0D0)
integer:: Npoints=1000
integer:: plpnl=50
integer:: pltnl=50
integer:: ipenl=1000
integer:: nwi=64
integer:: ipbnl=340
integer:: plnl=2300
integer:: ii,jj
real(wp):: rand
integer :: ip,ip1
integer :: io
COMPLEX(wp),dimension(:,:),allocatable :: integrand_prep_J
real(wp),dimension(:,:),allocatable :: real_integrand_prep_J
real(wp),dimension(:,:),allocatable :: imag_integrand_prep_J
COMPLEX(wp),dimension(:,:,:),allocatable :: integrand_prep_J_ip
REAL(wp) :: Coef
integer :: i_theC,i_phiC
REAL(wp),DIMENSION(3,3) :: matrice
REAL(wp),DIMENSION(:), allocatable :: wi
REAL(wp),DIMENSION(:,:), allocatable :: rprime_iwi1
REAL(wp),DIMENSION(:,:,:), allocatable :: C_grid_rhat
REAL(wp),DIMENSION(:,:,:,:), allocatable :: M12_surf_sph_obs
REAL(wp),DIMENSION(:,:,:,:), allocatable :: M12_sph_obs_obs
INTEGER :: i_wi
COMPLEX(wp) :: integrand_th,integrand_ph
COMPLEX(wp),DIMENSION(3) :: integrand_prep_J_iwi
complex(wp) :: E_theC,E_phiC,ctmp(3)
COMPLEX(wp),DIMENSION(3) :: integrand_J
COMPLEX(wp) :: deph_transl
REAL(wp) :: scalC
real(wp) :: rtmp(3),itmp(3),Ru1,Ru2,Ru3,Iu1,Iu2,Iu3
COMPLEX(wp),dimension(:,:,:,:),allocatable :: Uc
ALLOCATE(wi(nwi))
ALLOCATE(rprime_iwi1(3,nwi))
ALLOCATE(integrand_prep_J(3,nwi))
ALLOCATE(real_integrand_prep_J(3,nwi))
ALLOCATE(imag_integrand_prep_J(3,nwi))
ALLOCATE(integrand_prep_J_ip(3,nwi,ipeNL))
ALLOCATE(Uc(3,ipeNL,PLpNL,PLtNL))
ALLOCATE(M12_surf_sph_obs(PLpNL,PLtNL,3,3))
ALLOCATE(C_grid_rhat(3,PLpNL,PLtNL))
ALLOCATE(M12_sph_obs_obs(PLpNL,PLtNL,3,3))
do ip=1,Npoints
do i_wi=1,nwi
do ii=1,3
integrand_prep_J(ii,i_wi)=cmplx(rand(),rand(),wp)
integrand_prep_J_ip(ii,i_wi,ip)=integrand_prep_J(ii,i_wi)
enddo
enddo
enddo
do i_phiC=1,PLpNL
do i_theC=1,PLtNL
do jj=1,3
C_grid_rhat(jj,i_phiC,i_theC)=rand()
do ii=1,3
M12_surf_sph_obs(i_phiC,i_theC,ii,jj)=rand()
enddo
enddo
enddo
enddo
do i_wi=1,nwi
do ii=1,3
rprime_iwi1(ii,i_wi)=-1+rand()
enddo
enddo
!$acc region
do 10 ip=1,Npoints
io=ip
integrand_prep_J(:,:)=integrand_prep_J_ip(:,:,ip)
real_integrand_prep_J=real(integrand_prep_J)
imag_integrand_prep_J=imag(integrand_prep_J)
do 11 i_phiC=1,PLpNL
do 12 i_theC=1,PLtNL
matrice = M12_surf_sph_obs(i_phiC,i_theC,:,:)
E_theC = (0._wp,0._wp)
E_phiC = (0._wp,0._wp)
do i_wi=1,nwi
Rtmp(:)=real_integrand_prep_J(:,i_wi)
Itmp(:)=imag_integrand_prep_J(:,i_wi)
Ru1=matrice(1,1)*Rtmp(1) + matrice(1,2)*Rtmp(2) + matrice(1,3)*Rtmp(3)
Iu1=matrice(1,1)*Itmp(1) + matrice(1,2)*Itmp(2) + matrice(1,3)*Itmp(3)
Ru2=matrice(2,1)*Rtmp(1) + matrice(2,2)*Rtmp(2) + matrice(2,3)*Rtmp(3)
Iu2=matrice(2,1)*Itmp(1) + matrice(2,2)*Itmp(2) + matrice(2,3)*Itmp(3)
Ru3=matrice(3,1)*Rtmp(1) + matrice(3,2)*Rtmp(2) + matrice(3,3)*Rtmp(3)
Iu3=matrice(3,1)*Itmp(1) + matrice(3,2)*Itmp(2) + matrice(3,3)*Itmp(3)
integrand_J(1) = cmplx(Ru1,Iu1,wp)
integrand_J(2) = cmplx(Ru2,Iu2,wp)
integrand_J(3) = cmplx(Ru3,Iu3,wp)
scalC= C_grid_rhat(1,i_phiC,i_theC)*rprime_iwi1(1,i_wi)
scalC=scalC+C_grid_rhat(2,i_phiC,i_theC)*rprime_iwi1(2,i_wi)
scalC=scalC+C_grid_rhat(3,i_phiC,i_theC)*rprime_iwi1(3,i_wi)
ru3=cos(scalC)
iu3=sin(scalC)
integrand_th=cmplx(ru1ru3-iu1iu3,ru3iu1+ru1iu3,wp)
integrand_ph=cmplx(ru2ru3-iu2iu3,ru3iu2+ru2iu3,wp)
E_theC = E_theC + integrand_thwi(i_wi)
E_phiC = E_phiC + integrand_phwi(i_wi)
end do
matrice = M12_sph_obs_obs(i_phiC,i_theC,:,:)
Rtmp(1)=Real(E_theC)
Itmp(1)=Imag(E_theC)
Rtmp(2)=Real(E_phiC)
Itmp(2)=Imag(E_phiC)
Uc(1,io,i_phiC,i_theC) = cmplx(Ru1,Iu1,wp)
Uc(2,io,i_phiC,i_theC) = cmplx(Ru2,Iu2,wp)
Uc(3,io,i_phiC,i_theC) = cmplx(Ru3,Iu3,wp)
12 continue
11 continue
10 continue
!$acc end region
END
I have also runtime problems when it is compiled with:
pgfortran -ta=nvidia -Minfo=accel -fast code.f90
Anyone can help?
With thanks,
Barak Galanti
