Linux version : Ubuntu 16.04 LTS
GPU type : GeForce GTX 1080
nvidia driver version : 410.93
CUDA version : 10.0
CUDNN version : 7.4.1
Python version [Anaconda] : 3.6.8
Tensorflow version : tensorflow-gpu 1.13.1
TensorRT version : 5.1.2.2
[libprotobuf FATAL /home/erisuser/p4sw/sw/gpgpu/MachineLearning/DIT/externals/protobuf/x86_64/10.0/include/google/protobuf/repeated_field.h:1408] CHECK failed: (index) < (current_size_):
File "detect_objects.py", line 245, in <module>
main()
File "detect_objects.py", line 219, in main
batch_size=args.max_batch_size)
File "/home/zcy/1_data_sets/TensorRT-5.1.2.2/targets/x86_64-linux-gnu/samples/python/uff_ssd/utils/inference.py", line 115, in __init__
batch_size=batch_size)
File "/home/zcy/1_data_sets/TensorRT-5.1.2.2/targets/x86_64-linux-gnu/samples/python/uff_ssd/utils/engine.py", line 75, in build_engine
parser.parse(uff_model_path, network)
RuntimeError: CHECK failed: (index) < (current_size_):
I am using the uff_ssd example in tensorrt5.1.2.2.
I trained my model with ‘ssd_inception_v2_coco.config’ in tensorflow-api. When I used the script detect_objects.py in uff_ssd, the model was converted from ‘.pb’ to ‘.uff’ and also generated '.pbtxt 'File.
But when building an engine, there is always the same error. The error message is as above.
When I use the default model ‘ssd_inception_v2_coco_2017_11_17’ in the uff_ssd script ‘detect_objects.py’, everything works fine.
Any help will be appreciated!!!
