Does the Orin Nano support SATA for memory?
Please check the Flashing Support — Jetson Linux Developer Guide documentation (nvidia.com) to know what are supported.
Incidentally, you might want to include a use-case behind the question. For example, if you are asking about swap over a SATA drive, the answer should be “yes”, but if you want to make more memory available for CUDA, then the answer would be “no” (CUDA requires physical RAM).
