Save annotation data from tracker from deepstream
• Hardware Platform (Jetson / GPU) GPU-GTX 1050
• DeepStream Version 5.1
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 460.91.03
• Issue Type( questions, new requirements, bugs) Questions
Hi, I can’t get the annotation files from deepstream (detection + tracker).
If i using only detection it is work good. (gie-kitti-output-dir=/dir/), bun when i add tracker (enable=1), the annotation don’t save. (kitti-track-output-dir=­/dir/).
What am I doing wrong?
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
#gie-kitti-output-dir=/home/dir/
kitti-track-output-dir=­/home/dir/
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
num-sources=1
uri=file:/home/dir/test.mp4
gpu-id=0
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
[sink0]
#display on/off
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
[primary-gie]
enable=1
gpu-id=0
# Modify as necessary
batch-size=1
bbox-border-color2=0;0;1;1
bbox-bg-color2=-0;1;0;0.6
operate-on-class-ids=2
gie-unique-id=1
config-file=/opt/nvidia/deepstream/deepstream/samples/configs/config_infer_primary_peoplenet.txt
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=test_blur_low_th.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=3
#1=h264 2=h265
codec=1
enc-type=0
sync=0
<b>source-id=1</b>
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[tracker]
enable=1
tracker-width=960
tracker-height=544
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=../deepstream-app/tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
tracking-surface-type=1
enable-past-frame=1
[tests]
file-loop=0
Please check if you can access /home/dir/ you set to kitti-track-output-dir
Yes, i can.
If i choose gie-kitti-output-dir with the same directory - annotations are saved well.
Did the tracker working?
