We are using deepstream6.2 and Deepstream-test5, SDK. By enabling the smart recording feature, we are able to save the videos in periodic intervals from the source;
[source0]
enable=1
type=4
uri=rtsp://localhost:8554/ds-test
num-sources=1
gpu-id=0
cudadec-memtype=0
smart-record=2
smart-rec-container=0
#smart-rec-start-time=6
smart-rec-duration=30
smart-rec-file-prefix=smart_record
smart-rec-dir-path=/home/ds_configs/video-storage/source0
smart-rec-video-cache=30
However we want to save the inference results(videos with bounding boxes/class labels/trackids) in periodic intervals, say for every 60 seconds. we are able to do this using deepstreamsr. But not sure how to integrate this feature to the deepstream-test5 application.Please let us known to enable smart recording for sink inside the test5 application
• DeepStream Version
• TensorRT Version
Thu Jun 1 09:33:47 2023
| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P0 N/A / N/A | 5MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2550 G /usr/lib/xorg/Xorg 4MiB |
• DeepStream Version: 6.2
• Issue Type( questions, new requirements, bugs):Adding a new requirement to save the inference results as periodic intervals inside the test5 application
• How to reproduce the issue ?
We have made some changes in the deep_sink_bin.c using the splitmuxsink to save the the inference results in mp4 format.But the changes reproduce the below issue
** ERROR: <create_multi_source_bin:1490>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1583>: create_multi_source_bin failed
** ERROR: <create_pipeline:1485>: create_pipeline failed
** ERROR: main:1472: Failed to create pipeline
Quitting
App run failed
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description deepstream_sink_bin.c (33.3 KB) deepstream_config.h (3.6 KB) deepstream_sinks.h (4.8 KB)
I am also attaching the codes for your reference. We need your guidance on adding the code base to sink for saving video files in periodic intervals
please open more logs to check which element was created failed. please do “export GST_DEBUG=3” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
here is a sample to use splitmuxsink , you only need to modify the sink.
gst-launch-1.0 videotestsrc num-buffers=500 ! video/x-raw,width=320,height=240 ! videoconvert ! queue ! timeoverlay ! x264enc key-int-max=10 ! h264parse ! splitmuxsink location=video%02d.mov max-size-time=10000000000 max-size-bytes=1000000
Thank You! I am able to save the video files after modifying the sink. How ever I want to save the video files for every one minute or one hour. The g-streamer command you shared saves the video file for less than a second
How to modify the statement for recording the videos for one hour /one minute
is this storing smart record event video or else store the segment of the video means every 10 segment and i am also doing smart record event but i my case smart record event is store in every 10 seconds how to change this
