Hi WayneWWW
What is the result of your attempt? Double monitor tear is resolved?
My project needs a dual monitor, but I have the same problem. Can you give me some suggestions?
Many users have encountered a problem.
There are some problems with the nvidia dual monitor display driver? Whether there are some ways to solve the problem.
How to Fix Most Screen Tearing with Nvidia GPUs
Hi WayneWWW
what is the result for your device .
Thankyou
I cannot reproduce this issue on my device. With a 60fps HDMI monitor + DSI panel, I only see my vsync app refresh with 60 fps.
Are you using Jetpack3.1? Could you also try cuda sample provided in jetpack3.1? There should be a sample named “SimpleGL”.
HI,
Can you use xrandr in your environment and share the results?
Can you use my demo application?
Thank you !
glbuffertest-master.zip (1.36 KB)
Hi,WayneWWW
thank you for sharing you result !
Yes i am using jetpack3.1. Screen tear with master.zip demo.
Can you use glbuffertest-master.zip demo with 1080p60fps HDMI monitor + 720p50fps DSI panel and share your results?
Hi
I am using the jetpack3.1.
Hi
I using your demo application , but the result is not chaged .
and WayneWWW can you use this demo application , and you can sharing your result
Thank you
This is my xrandr result.
DSI-0 connected primary 1200x1920+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1200x1920 60.00*+
HDMI-0 connected 1920x1080+1200+0 (normal left inverted right x axis y axis) 600mm x 340mm
1920x1080 60.00*+ 59.95 50.00 24.00 23.98
1680x1050 59.96
1440x900 74.99 59.89
1280x1024 75.03 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.01
832x624 75.05
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 75.00 72.81 67.06 59.94 59.94
Hi
I want to known you using the demo for your environment ,
how about the result ? and not just using the xrandr
Thank you
Hi
Can you use the demo in your environment need full screen display, if not full screen display and it’s not tearing
Hi WayneWWW
My device always have screen tearing with dual monitor , I try to modify follow your method , but the result is not chaged could
you tell me another method for dual monitor .
Thank you
Hi 18321083174,
I can reproduce this issue on my device by using your app. Checking internally.
Hi WayneWWW
Did your test results come out?
Still checking the root cause of this issue. Must you use GLUT?
Hi WayneWWW
I am not must use GLUT,are you have any other method for dual monitor,could you tell me?
Thank you
Hi WayneWWW
Did the test result come out ?
