I want to install Jetpack 5.0.2 on my Jetson Orin nano device. But the download page only provides the image for JETSON XAVIER NX DEVELOPER KIT.
Is there an image for Orin as well?
I’ll add that Orin is the newest of the hardware, and that the JetPack 5 is also the newest (though JetPack 6 will probably be out soon). Sometimes on L4T R32.x of older hardware there are only minor changes between releases, but there are so many changes in the L4T R35.x (which JetPack 5.x is for) that it is worthwhile to upgrade. 5.0.2 in particular had a lot of issues and was more of a pre-release.
Also: On SD card models you should also flash the module, not just change the SD card image. The boot content and equivalent of BIOS goes into the QSPI memory on the Orin Nano module, and it is important that the QSPI be compatible with the SD card image.
