the LIB variable in common/common.mk should include an -rpath-link for $(CUDA_INSTALL_PATH)/lib since libcudart.so uses libtlshook.so and this is not found by ld, e.g.:
-L$(CUDA_INSTALL_PATH)/lib -Wl,-rpath-link,$(CUDA_INSTALL_PATH)/lib
platform: fedora core 5 i386
regards
What is your $(CUDA_INSTALL_PATH), and did you add $(CUDA_INSTALL_PATH)/lib to /etc/ld.so.conf ?
Set LD_LIBRARY_PATH (as in the readme).
export LD_LIBRARY_PATH=$(CUDA_INSTALL_PATH)/lib:$LD_LIBRARY_PATH
no i did not want to add the cuda library path to ld.so.conf. also, afaik LD_LIBRARY_PATH settings are only used by ld.so (the runtime linker) and not ld itself, but i might be wrong on this one. cuda and the sdk where installed out-of-tree on purpose.
I also needed to modify common/common.mk of the 0.9 beta SDK.
On the (now supported) SuSE 10.2 it can’t run the GL projects because Xmu is not on the link line. I needed to add -L/usr/X11R6/lib -lXmu to the LIB variable.
Distri is SuSE 10.2 default install (32bit) with all current updates + the 100.14.10 driver.
Peter
The common.mk is consistent with the readme.
With LD_LIBRARY_PATH, it will work and you can easily switch between different distros.
If you don’t want to use it, hardcode the path with rpath.
I know this is off-topic, but where can I download the version 0.9 ?
Or is it only for registered developers ?
