Hi
Just built a box to play with Cuda - got as far as compiling the SDK examples and get the following error:
az@AzCUDA:~/NVIDIA_CUDA_SDK$ make
make[1]: Entering directory /home/az/NVIDIA_CUDA_SDK/common' a - obj/release/bank_checker.cpp_o a - obj/release/cmd_[b][/b]arg_reader.cpp_o a - obj/release/cutil.cpp_o a - obj/release/stopwatch.cpp_o a - obj/release/stopwatch_linux.cpp_o a - obj/release/multithreading.cpp_o make[1]: Leaving directory /home/az/NVIDIA_CUDA_SDK/common’
make[1]: Entering directory /home/az/NVIDIA_CUDA_SDK/common' In file included from ./../common/inc/paramgl.h:13, from src/paramgl.cpp:8: [b]./../common/inc/GL/glut.h:60:20: error: GL/glu.h: No such file or directory[/b] make[1]: *** [obj/release/paramgl.cpp_o] Error 1 make[1]: Leaving directory /home/az/NVIDIA_CUDA_SDK/common’
make: *** [lib/libparamgl.so] Error 2
Googling suggest it’s down to missing GL and/or X headers (no X with server edition of ubuntu) and that installing
“libgl1-mesa-dev or mesa-common-dev. After you’ve installed those it should work.”
I’m a bit confused as to whether this file is inside the SDK, and if it is how installing something else can make it appear in the SDK…are the files created in the extraction of the SDK conditional on other installed things? Presumably i’d have to re-extract the SDK after installing
apt doesnt know about these packages, using the file completion in apt:
az@AzCUDA:~/NVIDIA_CUDA_SDK$ sudo apt-get install libgl
libgl1 libglade2-dev libglib2.0-doc
libgl1-mesa libgl-dev libglibmm-2.4-1c2a
libgl1-mesa-dev libglib1.2 libglu1
libgl1-mesa-dri libglib2.0-0 libglu1-mesa
libgl1-mesa-glx libglib2.0-cil libglu1-mesa-dev
libglade0 libglib2.0-data libglu1-xorg-dev
libglade2-0 libglib2.0-dev libglu-dev
none of the likely candidates seem to exist, e.g.:
az@AzCUDA:~/NVIDIA_CUDA_SDK$ sudo apt-get install libglu1-mesa-dev
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package libglu1-mesa-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package libglu1-mesa-dev has no installation candidate
any ideas what I should install? do I need more sources for apt?
Many thanks
virgesmith
