SDK manager is set at a fixed size
As you can see my sdk manager is set at a fixed height and width so I’m unable to select certain options. On top of this there is not close button in the top right. I am running ubuntu 22.04. I have tried uninstalling and reinstalling the sdk manager but with no luck. Any advice would be much appreciated.
May I know what’s your display resolution?
The screen resolution equal to or larger than 1440x900 is recommended for GUI mode.
Currently running on 1920x1080. I have figured out the issue. I have a two monitor setup and the secondary monitor was vertical. Running sdk manager with this secondary monitor plugged in would result in the error (on the primary screen) but running it with only the primary monitor hooked up caused sdk manager to boot fine.
