所以你現在哪一片module跟這一條topic碰到一樣的問題?
請你選下面那個"EXPORT LOGS" 然後把log貼上來
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-04-24_18-31-33.zip (121.1 KB)
OK
Are you using devkit or custom board?
The log in below should be from a custom board. If you all use same board to flash the board, please file a new topic.
If you are on devkit, then we can track on current topic.
I`m using custom board. so I want to know which version to burn for AGX-ORIN-64GB with custom board?
None of the version work. SDKM does not support custom board.
That was why I asked you to file a new topic…
您好!
NX 模块上电后,运行到这个就停下来,是什么情况?
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
不確定. 都是case by case. 你需要提供更多info才能判斷
