Hello everyone—I’m working on an ADAS setup using the Jetson Orin Nano, and I need a camera module with a field of view between 80° and 120°. Compatibility via MIPI‑CSI is preferred, but I’m open to USB options if they simplify integration.
Key concerns: JetPack driver support, HDR capability, resolution, lens flexibility. Does anyone have experience using these modules on Orin Nano? Are there better alternatives—USB or MIPI‑CSI—that have delivered reliable wide‑angle ADAS results?
Also make sure that the camera should have drivers and is compaitible with jetson orin nano
Can you specify and tell me some cameras which I cane use because I have already bought arducam imx708 but when I tried using it on my jetson orin nano I came to know that the imx708 doesn’t have proper drivers for this orin so can you just tell me some of the camera which I can use just tell me names
