What is the easiest way to use a global shutter camera with orin nano. Is usb based camera better than csi. For eq. does Arducam ov9782 usb camera work out of the box on orin nano. Any suggestions?
Thanks,
Thanks,
Bu default USB cameras is supported by default through Linux kernel UVC driver. Ideally any USB camera is supposed to work on Jetson platforms. You may check the steps in
Jetson AGX Orin FAQ
