Does anyone know how to setup a USB 3.0 camera with Jetson orion nano, the camera model is MER2-503-36U3C?
I have setup my jetson orion nano.
Congratulations on setting up your Jetson Orin Nano! Now that you have your device up and running, let’s go through some key information to help you get started.
Hardware Requirements:
  • You have a Jetson Orin Nano device, which is a powerful AI computer that can be used for a variety of applications, including computer vision, robotics, and more.
  • You have a carrier board, specifically the Jetson Orin Nano reference carrier board (P3768-0000), which supports all the Jetson Orin Nano Series and Jetson Orin NX Series modules.
  • You have a USB-C flashing cable, a monitor, keyboard, and mouse, which are necessary for setting up and interacting with your device.
Software Requirements:
  • You have JetPack 6.2/Jetson Linux 36.4.3 installed on your device, which is the recommended software for the Jetson Orin Nano.
  • You have Jetson Platform Services 2.0 installed, which provides a set of tools and services for managing and optimizing your device.
Getting Started:
  • To get started with your Jetson Orin Nano, you can refer to the Jetson Setup Guide, which provides a step-by-step guide for setting up your device.
  • You can also refer to the Quick Start Guide, which provides a brief overview of the hardware and software requirements, as well as the setup process.
  • If you need more detailed information on power and performance management features, you can refer to the Jetson Orin Nano Series, Jetson Orin NX Series, and Jetson AGX Orin Series documentation.
Configuring the CSI Connector:
  • If you need to configure the CSI connector on your Jetson Orin Nano, you can refer to the Configuring the CSI Connector section, which provides a step-by-step guide for configuring the connector.
Comparison with Other Jetson Devices:
  • The Jetson Orin Nano is a powerful device that is similar to other Jetson devices, such as the Jetson Orin NX and Jetson AGX Orin.
  • However, the Jetson Orin Nano has some unique features, such as its compact size and low power consumption, which make it ideal for certain applications.
  • If you need to compare the features and specifications of different Jetson devices, you can refer to the Jetson Modules and Configurations table, which provides a detailed comparison of the different devices.
I hope this information helps you get started with your Jetson Orin Nano! If you have any further questions or need more information, feel free to ask.
If the camera supports UVC driver, it will be detected if you connect to either type-A port and boot the developer kit.
If it needs additional driver, please check with the vendor for technical support.
