Seg fault during second cuda kernel call
The code gets segmentation fault in the initial stage of execution. After debugging the code with cuda-gdb, it shows following message:
The debugging info is as follows:
(cuda-gdb) step
Single stepping until exit from function cudaSetupArgument,
which has no line number information.
[Launch of CUDA Kernel 0 (AssignInputs<<<(1,1,1),(1,1,1)>>>) on Device 0]
[Launch of CUDA Kernel 1 (AssignNodes<<<(1,1,1),(1,1,1)>>>) on Device 0]
Program received signal CUDA_EXCEPTION_10, Device Illegal Address.
[Switching focus to CUDA kernel 1, grid 2, block (0,0,0), thread (0,0,0), device 0, sm 1, warp 1, lane 0]
0x000000000d5a9520 in AssignNodes<<<(1,1,1),(1,1,1)>>> ()
(cuda-gdb) step
Single stepping until exit from function _Z11AssignNodesP5_rootPdPi,
Program terminated with signal CUDA_EXCEPTION_10, Device Illegal Address.
The program no longer exists.
Can somebody tell what went wrong here? Is there any tool to debug further?
Could You provide Your kernel and host code, should it be not a close source External Image ?
Regards,
MK
Following is the code snippet:
R *r, *r_d;
P *p;
N *n;    // R is the main struct. P & N are sub structures of R. Also, N is linkedlist
// The linked list N is created inside CUDA by using the arrays which are copied from host
double *nAr,*nAr_d;
int numNAr;
nAr = (double *) malloc(1*sizeof(double));
while(!feof(fp))
       nAr = (double *)realloc(nAr, (i+1)*sizeof(double));
       fscanf(fp, "%lf", &nAr[i]);
       i=i+1;
fclose(fp);
numNAr = i/2;
cudaMalloc( (void **) &nAr_d, numNAr * 2 * sizeof(double));
cudaMemcpy(nAr_d, nAr, numNAr * 2* sizeof(double), cudaMemcpyHostToDevice);
AssignKernel2<<<1,1>>> (root_dev, nAr_d, numNAr);
cudaThreadSynchronize();
The code for AssignKernel is as follows:
__global__ void AssignKernel2(R *r_d,double *nAr_d,int numNAr_d)
        int i,iN, dInc, numNb, nT=0;
        double    bSX, bSY, bSZ;
N *n;
        P *p;
        p = r_d->p;
r_d->nNKM = 0;
p->nC = 0;
r_d->nNQ = (N *)NULL;
n = (N *) malloc(1*sizeof(N));
r_dev->nKs = (N **) malloc(((numNAr_d) + 5) * sizeof(  N *));
for(i=0; i<numNAr_d; i++)
                p->nC = para->nC + 1;
if(nT >= r_d->nNKM)
                        ENKs(r_d, r_d->nNKM + 1);
                n->mT.idx = nT;
n->numNb = 2;
                n->x = nAr_d[2*i];
                n->y = nAr_d[2*i+1];
                n->x = n->x * p->b;
                n->y = n->y * p->b;
The AssignKernel2 is the 2nd cuda kernel. There is no error in 1st cuda kernel call.
The cuda-gdb shows following information:
215			while(fgetc(fp)!='.');
(cuda-gdb) step 10
dim3 (this=0x7fffe70672b0, vx=1, vy=1, vz=1) at /usr/local/cuda/bin/../include/vector_types.h:497
497	    __host__ __device__ dim3(unsigned int vx = 1, unsigned int vy = 1, unsigned int vz = 1) : x(vx), y(vy), z(vz) {}
(cuda-gdb) step
dim3 (this=0x7fffe70672c0, vx=1, vy=1, vz=1) at /usr/local/cuda/bin/../include/vector_types.h:497
(cuda-gdb) list
492	/*DEVICE_BUILTIN*/
493	struct dim3
494	{
495	    unsigned int x, y, z;
496	#if defined(__cplusplus)
498	    __host__ __device__ dim3(uint3 v) : x(v.x), y(v.y), z(v.z) {}
499	    __host__ __device__ operator uint3(void) { uint3 t; t.x = x; t.y = y; t.z = z; return t; }
500	#endif /* __cplusplus */
501	};
(cuda-gdb) step
0x0000000000401800 in __device_stub__Z12AssignKernel1P5_rootPd (__par0=0x0, __par1=0x7fffe70676e0) at Main.cudafe1.stub.c:1
1	#include "crt/host_runtime.h"
(cuda-gdb) step
0x0000000000401810	2	#include "Main.fatbin.c"
(cuda-gdb) step
0x00000000004017a0 in ?? () at ll_kernel.cu:114
warning: Source file is more recent than executable.
114	/*
(cuda-gdb) step
0x00000000004017b0	1	#include "crt/host_runtime.h"
(cuda-gdb) step
0x00002b3bf5963930 in ?? () from /usr/local/cuda/lib64/libcudart.so.4
(cuda-gdb) step
[Launch of CUDA Kernel 0 (AssignKernel1<<<(1,1,1),(1,1,1)>>>) on Device 0]
Number of Ns = 100
[Launch of CUDA Kernel 1 (AssignKernel2<<<(1,1,1),(1,1,1)>>>) on Device 0]
Failed to read the virtual PC on CUDA device 0 (error=10).
(cuda-gdb) step
(cuda-gdb) continue
Continuing.
(cuda-gdb) q
The program is running.  Exit anyway? (y or n) y
Here its not showing any line number, which is causing the error. How to get that info?
The cuda-memcheck output is as follows:
# cuda-memcheck ./gpu_debug.exe
========= CUDA-MEMCHECK
Number of Ns = 100
========= Error: process didn't terminate successfully
========= Out-of-range Shared or Local Address
=========     in ll_kernel.cu:AssignKernel2
=========     by thread (0,0,0) in block (0,0,0)
========= ERROR SUMMARY: 1 error
Please let me know how to diagnose it further.
Hi sanf, could you post the entire source of the application? Also, which version of the toolkit and the driver are you using ? Finally, have you tried enabling cuda memcheck within cuda-gdb ? You can do this by typing “set cuda memcheck on” at the cuda-gdb prompt before starting the application.
Compile your code with [font=“Courier New”]-G0[/font] before starting cuda-gdb for more useful output from it. And make sure you do not touch the source code after compiling and before starting cuda-gdb, or cuda-gdb will show you the wrong source code.
