Description
I retrained the ssd resnet 50 v1 fpn 640x640 and exported to ONNX successfully. When I try to export it to TensorRT using the code here: Speeding Up Deep Learning Inference Using TensorFlow, ONNX, and NVIDIA TensorRT | NVIDIA Technical Blog, the segfault error appears.
I tried ./trtexec --onnx=model.onnx --verbose --explicitBatch
and got the same error
trt_log.txt (51.6 KB)
Using the code in the NVIDIA TENSORRT DOCUMENTATION at the section Importing from ONNX using Python gives me the same error
Developer Guide :: NVIDIA Deep Learning TensorRT Documentation
After using gdb I got a new error:
0x0000007fa957d0f8 in nvinfer1::plugin::BatchedNMSPlugin::getOutputDataType(int, nvinfer1::DataType const*, int) const ()
from /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7
Environment
- TensorRT Version: 7.1.3
- GPU Type: Jetson Nano
- Nvidia Driver Version: JetPack-4.5
- CUDA Version: 10.2
- CUDNN Version: 8.0.0
- Python Version: 3.6.9
- Baremetal or Container: Baremetal
Notes
- The command used to export the model to ONNX is:
python -m tf2onnx.convert --saved-model saved_model --output model_resnet.onnx --fold_const --tag serve --verbose --opset 12
- The input
dtype
of the ONNX model was changed tonp.float32
sinceINT8
is not compatible with TensorRT - Layer + Register API was used to replace the NMS TensorFlow uses with
BatchedNMS_TRT
(I dont think this is a problem since the log I uploaded saysSuccessfully created plugin: BatchedNMS_TRT
) - I have tried changing the
builder.max_workspace_size()
in the code from the blog to different values with no success(1 << 30), (3 << 30)
(It crashes even faster) - When I used
onnx.checker.check_model()
I got an error that no op was registered as BatchedNMS_TRT for domain_version 12. However, apparently that op is not technically a valid ONNX op so this is expected. Plus the trtexec log saysSuccessfully created plugin: BatchedNMS_TRT
Possible solutions
- Using an earlier JetPack version?
- Using
CombinedNonMaxSuppression
in the TensorFlow model? Since I read in a post made by @klinten that
BatchedNMSPlugin is modeled directly after the TensorFlow CombinedNMS
I dont know it this would be more ‘compatible’ with TensorRT, thus solving my problem
- Optimizing the model a bit more before exporting to TensorRT? (if the problem occurs because of low memory)
So once again the question is:
How do I export my ONNX model to TensorRT?
Thanks in advance for your help :)
