Convert ssd_resnet50_v1_coco onnx to TensorRT
Description
I trained a SSD Resnet50_v1_coco using the Tensorflow Object Detection API, then I succesfully converted the SavedModel to onnx using tf2onnx.convert, but when trying to convert it to TensorRT it failed as layer “Non_Max_Supression” is apparently not supported in TensorRT. What is the most appropiate way to solve this?
I 've traied modifying thee onnx model using onnx-graphsurgeon by replacing the unsopported layer with “BatchedNMS_TRT” with no succes (the code is posted below).
Environment
TensorRT Version: 8
GPU Type: Nvidia rtx 2060
Nvidia Driver Version: 460.73.01
CUDA Version: 11.2
CUDNN Version: 8
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8.5
TensorFlow Version (if applicable): 2.4.1
Steps To Reproduce
@gs.Graph.register()
def trt_batched_nms(self, boxes_input, scores_input, nms_output,
                share_location, num_classes):
boxes_input.outputs.clear()
scores_input.outputs.clear()
nms_output.inputs.clear()
attrs = {
    "shareLocation": share_location,
    "numClasses": num_classes,
    "backgroundLabelId": 0,
    "topK": 116740,
    "keepTopK": 100,
    "scoreThreshold": 0.3,
    "iouThreshold": 0.6,
    "isNormalized": True,
    "clipBoxes": True
return self.layer(op="BatchedNMS_TRT", attrs=attrs,
                  inputs=[boxes_input, scores_input],
                  outputs=[nms_output])
graph.inputs[0].shape=[1,320,320,3]
print(graph.inputs[0])
print(graph.inputs[0].shape)
for inp in graph.inputs:
inp.dtype = np.int
input = graph.inputs[0]
tmap = graph.tensors()
graph.trt_batched_nms(tmap[“StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/unstack__830:0”],
                  tmap["Unsqueeze__833:0"],
                  tmap["NonMaxSuppression__837:0"],
                  share_location=True,
                  num_classes=4)
graph.cleanup()
graph.toposort()
onnx.checker.check_model(gs.export_onnx(graph))
onnx.save_model(gs.export_onnx(graph), output_model_path)
When perfoming onnx.checker.check_model an error pops up, as apparently unsqueeze op has an invalid input shape = [1] when the min limit and max limit both are equal to 2. Any recommendations?
Thanks in advance.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
