It appears with certain combination of GL/Vulkan calls it is possible to make libGL segfault. Initially found when investigating issue in recent Hitman update:
Attached minimal reproducer (assumes presence of SDL2 and Vulkan) and nvidia-bug-report output.
output in dmesg upon segfault:
[10191.383917] NVRM: Xid (PCI:0000:01:00): 31, Ch 00000018, engmask 00000111, intr 10000000
gdb stacktrace:
Program received signal SIGSEGV, Segmentation fault.
0x00007fffe9beb460 in ?? ()
(gdb) bt
#0 0x00007fffe9beb460 in ?? ()
#1 0x00007fffec490619 in ?? () from /usr/lib64/nvidia/libGL.so.1
#2 0x00007fffec48aab9 in ?? () from /usr/lib64/nvidia/libGL.so.1
#3 0x00007fffec483ca6 in glXGetProcAddress () from /usr/lib64/nvidia/libGL.so.1
#4 0x00007ffff7b7f3e6 in X11_GL_LoadLibrary (_this=0x60d420, path=<optimized out>) at /usr/src/debug/SDL2-2.0.5/src/video/x11/SDL_x11opengl.c:193
#5 0x00007ffff7b6f836 in SDL_GL_LoadLibrary_REAL (path=path@entry=0x0) at /usr/src/debug/SDL2-2.0.5/src/video/SDL_video.c:2729
#6 0x00007ffff7b71779 in SDL_CreateWindow_REAL (title=0x4008b4 "", x=<optimized out>, y=0, w=1, h=1, flags=26) at /usr/src/debug/SDL2-2.0.5/src/video/SDL_video.c:1371
#7 0x0000000000400827 in main (argc=1, argv=0x7fffffffd268) at reproducer.c:11
reproducer.c (328 Bytes)
Makefile.txt (180 Bytes)
