Dota 2 works fine with opengl renderer though.
Vulkaninfo: vulkaninfo_415.txt · GitHub
I have the same results with every driver version that build against 4.19 kernel (drivers in 410 series, previous versions in 415 series, etc)
ERROR! VK call failed! result = VK_ERROR_OUT_OF_HOST_MEMORY ( vkCreateFence( VulkanDevice(), &fenceCreateInfo, NULL, pFence->GetPtr() ) )
ERROR! VK call failed! result = VK_ERROR_DEVICE_LOST ( vkQueueSubmit( pQueue, 1, &submitInfo, pFence->Get() ) )
ERROR! VK call failed! result = VK_ERROR_OUT_OF_HOST_MEMORY ( vkCreateFence( VulkanDevice(), &fenceCreateInfo, NULL, &presentFence.m_pFence ) )
ERROR! VK call failed! result = VK_ERROR_DEVICE_LOST ( vkQueueSubmit( VulkanQueue(), 1, &submitInfo, presentFence.m_pFence ) )
Thread 14 "VKRenderThread" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7f653f54a700 (LWP 31254)]
0x00007f654cd1acb4 in ?? () from /usr/lib64/libnvidia-glcore.so.415.22
Argument list to give program being debugged when it is started is "-vulkan".
(gdb) bt
#0 0x00007f654cd1acb4 in ?? () from /usr/lib64/libnvidia-glcore.so.415.22
#1 0x00007f654260b542 in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/librendersystemvulkan.so
#2 0x00007f654260e010 in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/librendersystemvulkan.so
#3 0x00007f654258999b in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/librendersystemvulkan.so
#4 0x00007f654258a070 in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/librendersystemvulkan.so
#5 0x00007f65425d4aa9 in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/librendersystemvulkan.so
#6 0x00007f6548532e4e in ?? () from /home/theli/.local/share/Steam/steamapps/common/Artifact/game/bin/linuxsteamrt64/libtier0.so
#7 0x00007f654e88d0da in start_thread (arg=0x7f653f54a700) at pthread_create.c:486
#8 0x00007f654e5bfd1f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
[ 2595.167017] NVRM: Xid (PCI:0000:01:00): 31, Ch 00000036, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_14700000. Fault is of type FAULT_PDE ACCESS_TYPE_WRITE
[ 2599.327966] dota2[6673]: segfault at 60 ip 00007f0c78f97581 sp 00007ffda0b0e8b0 error 4 in libnvidia-glcore.so.415.22[7f0c77e38000+11de000]
[ 2599.327972] Code: c7 83 d0 01 00 00 06 19 00 00 48 8b 85 80 00 00 00 48 8b 80 c8 00 00 00 4a 8b 94 20 10 03 00 00 48 b8 ff ff ff ff ff ff ff 3f <48> 23 42 60 48 03 83 d8 02 00 00 48 89 03 f6 85 9c 00 00 00 04 0f
I do have other vulkan things working (eg DOOM (2016) with vulkan renderer in Wine, and some dx11 games with dxvk as well)
Weird things is if I capture trace of Dota startup with vktrace I can replay it with vkreplay just fine (it only goes as far as displaying logo fullscreen though), it just complains of unexpected success:
vkreplay error: Return value VK_SUCCESS from API call (vkQueueWaitIdle) does not match return value from trace file VK_ERROR_DEVICE_LOST.
vkreplay error: Failed to replay packet_id 38, with global_packet_index 36472.
vkreplay error: Return value VK_SUCCESS from API call (vkCreateFence) does not match return value from trace file VK_ERROR_OUT_OF_HOST_MEMORY.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 37226.
vkreplay error: Return value VK_SUCCESS from API call (vkQueueSubmit) does not match return value from trace file VK_ERROR_DEVICE_LOST.
vkreplay error: Failed to replay packet_id 37, with global_packet_index 37230.
vkreplay error: Return value VK_SUCCESS from API call (vkDeviceWaitIdle) does not match return value from trace file VK_ERROR_DEVICE_LOST.
vkreplay error: Failed to replay packet_id 39, with global_packet_index 37231.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 38540.
vkreplay error: Failed to replay packet_id 37, with global_packet_index 38544.
vkreplay error: Failed to replay packet_id 39, with global_packet_index 38545.
vkreplay error: Failed to replay packet_id 38, with global_packet_index 38547.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 44067.
vkreplay error: Failed to replay packet_id 37, with global_packet_index 44126.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 48107.
vkreplay error: Failed to replay packet_id 37, with global_packet_index 48152.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 50768.
vkreplay error: Failed to replay packet_id 37, with global_packet_index 50784.
vkreplay error: Failed to replay packet_id 54, with global_packet_index 50788.
nvidia-bug-report.log.gz (524 KB)
