vulkan segfaults when running with nvidia 387.x (12/22) and ubuntu 17.10
I have a nvidia 960m, always worked with previous ubuntu versions, but since i upgraded to 17.10 im unable to run vulkan, it always segfaults when running any vulkan test.
vulkaninfo:
VULKAN INFO
Vulkan API Version: 1.0.61
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_core_validation.json, version “1.1.0”
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_object_tracker.json, version “1.1.0”
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_parameter_validation.json, version “1.1.0”
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_standard_validation.json, version “1.1.1”
INFO: [loader] Code 0 : Encountered meta-layer VK_LAYER_LUNARG_standard_validation
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_threading.json, version “1.1.0”
INFO: [loader] Code 0 : Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_unique_objects.json, version “1.1.0”
INFO: [loader] Code 0 : Found manifest file /home/groo/.local/share/vulkan/implicit_layer.d/steamoverlay_i386.json, version “1.0.0”
INFO: [loader] Code 0 : Found manifest file /home/groo/.local/share/vulkan/implicit_layer.d/steamoverlay_x86_64.json, version “1.0.0”
INFO: [loader] Code 0 : Meta-layer VK_LAYER_LUNARG_standard_validation all 5 component layers appear to be valid.
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/intel_icd.x86_64.json, version “1.0.0”
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.x86_64.json, version “1.0.0”
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/intel_icd.i686.json, version “1.0.0”
ERROR: [loader] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_intel.so: cannot open shared object file: No such file or directory
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.i686.json, version “1.0.0”
ERROR: [loader] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_radeon.so: cannot open shared object file: No such file or directory
INFO: [loader] Code 0 : Found ICD manifest file /usr/share/vulkan/icd.d/intel_icd.x86_64.json, version “1.0.0”
INFO: [loader] Code 0 : Found ICD manifest file /usr/share/vulkan/icd.d/radeon_icd.x86_64.json, version “1.0.0”
INFO: [loader] Code 0 : Found ICD manifest file /usr/share/vulkan/icd.d/nvidia_icd.json, version “1.0.0”
Instance Extensions:
Instance Extensions count = 15
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities: extension revision 1
VK_KHR_get_physical_device_properties2: extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_EXT_debug_report : extension revision 8
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_display : extension revision 21
VK_KHX_device_group_creation : extension revision 1
Layers: count = 8
VK_LAYER_LUNARG_core_validation (LunarG Validation Layer) Vulkan version 1.0.61, layer version 1
Layer Extensions count = 1
VK_EXT_debug_report : extension revision 6
Devices count = 3
GPU id : 0 (GeForce GTX 960M)
Layer-Device Extensions count = 1
VK_EXT_debug_marker : extension revision 4
GPU id : 1 (Intel® HD Graphics 530 (Skylake GT2))
GPU id : 2 (Intel® HD Graphics 530 (Skylake GT2))
VK_LAYER_LUNARG_object_tracker (LunarG Validation Layer) Vulkan version 1.0.61, layer version 1
Devices count = 3
VK_LAYER_LUNARG_parameter_validation (LunarG Validation Layer) Vulkan version 1.0.61, layer version 1
Devices count = 3
VK_LAYER_LUNARG_standard_validation (LunarG Standard Validation) Vulkan version 1.0.61, layer version 1
Devices count = 3
VK_LAYER_GOOGLE_threading (Google Validation Layer) Vulkan version 1.0.61, layer version 1
Devices count = 3
Layer-Device Extensions count = 0
VK_LAYER_GOOGLE_unique_objects (Google Validation Layer) Vulkan version 1.0.61, layer version 1
Layer Extensions count = 0
Devices count = 3
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.0.3, layer version 1
Devices count = 3
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.0.3, layer version 1
Devices count = 3
Presentable Surfaces:
Surface type : VK_KHR_xcb_surface
Formats: count = 2
B8G8R8A8_UNORM
B8G8R8A8_SRGB
Present Modes: count = 3
FIFO_KHR
FIFO_RELAXED_KHR
IMMEDIATE_KHR
VkSurfaceCapabilitiesKHR:
    minImageCount       = 2
    maxImageCount       = 8
    currentExtent:
            width       = 256
            height      = 256
    minImageExtent:
            width       = 256
            height      = 256
    maxImageExtent:
            width       = 256
            height      = 256
    maxImageArrayLayers = 1
    supportedTransform:
            VK_SURFACE_TRANSFORM_IDENTITY_BIT_KHR
    currentTransform:
    supportedCompositeAlpha:
            VK_COMPOSITE_ALPHA_OPAQUE_BIT_KHR
    supportedUsageFlags:
            VK_IMAGE_USAGE_TRANSFER_SRC_BIT
            VK_IMAGE_USAGE_TRANSFER_DST_BIT
            VK_IMAGE_USAGE_SAMPLED_BIT
            VK_IMAGE_USAGE_STORAGE_BIT
            VK_IMAGE_USAGE_COLOR_ATTACHMENT_BIT
            VK_IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
    supportedSurfaceCounters:
            None
Formats: count = 2
B8G8R8A8_SRGB
B8G8R8A8_UNORM
IMMEDIATE_KHR
MAILBOX_KHR
FIFO_KHR
    minImageCount       = 2
    maxImageCount       = 0
    currentExtent:
            width       = 256
            height      = 256
    minImageExtent:
            width       = 256
            height      = 256
    maxImageExtent:
            width       = 256
            height      = 256
    supportedTransform:
    currentTransform:
            VK_COMPOSITE_ALPHA_INHERIT_BIT_KHR
            None
Formats: count = 2
B8G8R8A8_SRGB
B8G8R8A8_UNORM
IMMEDIATE_KHR
MAILBOX_KHR
FIFO_KHR
    minImageCount       = 2
    maxImageCount       = 0
    currentExtent:
            width       = 256
            height      = 256
    minImageExtent:
            width       = 256
            height      = 256
    maxImageExtent:
            width       = 256
            height      = 256
    supportedTransform:
    currentTransform:
            None
Device Properties and Extensions :
GPU0
VkPhysicalDeviceProperties:
    apiVersion     = 0x400038  (1.0.56)
    driverVersion  = 1623556096 (0x60c58000)
    vendorID       = 0x10de
    deviceID       = 0x139b
    deviceType     = DISCRETE_GPU
    deviceName     = GeForce GTX 960M
    VkPhysicalDeviceLimits:
            maxImageDimension1D                     = 16384
            maxImageDimension2D                     = 16384
            maxImageDimension3D                     = 2048
            maxImageDimensionCube                   = 16384
            maxImageArrayLayers                     = 2048
            maxTexelBufferElements                  = 0x8000000
            maxUniformBufferRange                   = 0x10000
            maxStorageBufferRange                   = 0x7fffffff
            maxPushConstantsSize                    = 256
            maxMemoryAllocationCount                = 4294967295
            maxSamplerAllocationCount               = 4000
            bufferImageGranularity                  = 0x10000
            sparseAddressSpaceSize                  = 0xffffffffffffffff
            maxBoundDescriptorSets                  = 8
            maxPerStageDescriptorSamplers           = 4000
            maxPerStageDescriptorUniformBuffers     = 12
            maxPerStageDescriptorStorageBuffers     = 4096
            maxPerStageDescriptorSampledImages      = 16384
            maxPerStageDescriptorStorageImages      = 16384
            maxPerStageDescriptorInputAttachments   = 8
            maxPerStageResources                    = 53268
            maxDescriptorSetSamplers                = 4000
            maxDescriptorSetUniformBuffers          = 72
            maxDescriptorSetUniformBuffersDynamic   = 72
            maxDescriptorSetStorageBuffers          = 4096
            maxDescriptorSetStorageBuffersDynamic   = 16
            maxDescriptorSetSampledImages           = 98304
            maxDescriptorSetStorageImages           = 98304
            maxDescriptorSetInputAttachments        = 8
            maxVertexInputAttributes                = 32
            maxVertexInputBindings                  = 32
            maxVertexInputAttributeOffset           = 0x7ff
            maxVertexInputBindingStride             = 0x800
            maxVertexOutputComponents               = 128
            maxTessellationGenerationLevel          = 64
            maxTessellationPatchSize                        = 32
            maxTessellationControlPerVertexInputComponents  = 128
            maxTessellationControlPerVertexOutputComponents = 128
            maxTessellationControlPerPatchOutputComponents  = 120
            maxTessellationControlTotalOutputComponents     = 4216
            maxTessellationEvaluationInputComponents        = 128
            maxTessellationEvaluationOutputComponents       = 128
            maxGeometryShaderInvocations            = 32
            maxGeometryInputComponents              = 128
            maxGeometryOutputComponents             = 128
            maxGeometryOutputVertices               = 1024
            maxGeometryTotalOutputComponents        = 1024
            maxFragmentInputComponents              = 128
            maxFragmentOutputAttachments            = 8
            maxFragmentDualSrcAttachments           = 1
            maxFragmentCombinedOutputResources      = 16
            maxComputeSharedMemorySize              = 0xc000
            maxComputeWorkGroupCount[0]             = 2147483647
            maxComputeWorkGroupCount[1]             = 65535
            maxComputeWorkGroupCount[2]             = 65535
            maxComputeWorkGroupInvocations          = 1536
            maxComputeWorkGroupSize[0]              = 1536
            maxComputeWorkGroupSize[1]              = 1024
            maxComputeWorkGroupSize[2]              = 64
            subPixelPrecisionBits                   = 8
            subTexelPrecisionBits                   = 8
            mipmapPrecisionBits                     = 8
            maxDrawIndexedIndexValue                = 4294967295
            maxDrawIndirectCount                    = 4294967295
            maxSamplerLodBias                       = 15.000000
            maxSamplerAnisotropy                    = 16.000000
            maxViewports                            = 16
            maxViewportDimensions[0]                = 16384
            maxViewportDimensions[1]                = 16384
            viewportBoundsRange[0]                  =-32768.000000
            viewportBoundsRange[1]                  = 32768.000000
            viewportSubPixelBits                    = 8
            minMemoryMapAlignment                   = 64
            minTexelBufferOffsetAlignment           = 0x10
            minUniformBufferOffsetAlignment         = 0x100
            minStorageBufferOffsetAlignment         = 0x20
            minTexelOffset                          = -8
            maxTexelOffset                          =  7
            minTexelGatherOffset                    =-32
            maxTexelGatherOffset                    = 31
            minInterpolationOffset                  =-0.500000
            maxInterpolationOffset                  = 0.437500
            subPixelInterpolationOffsetBits         = 4
            maxFramebufferWidth                     = 16384
            maxFramebufferHeight                    = 16384
            maxFramebufferLayers                    = 2048
            framebufferColorSampleCounts            = 15
            framebufferDepthSampleCounts            = 15
            framebufferStencilSampleCounts          = 15
            framebufferNoAttachmentsSampleCounts    = 15
            maxColorAttachments                     = 8
            sampledImageColorSampleCounts           = 15
            sampledImageDepthSampleCounts           = 15
            sampledImageStencilSampleCounts         = 15
            sampledImageIntegerSampleCounts         = 15
            storageImageSampleCounts                = 15
            maxSampleMaskWords                      = 1
            timestampComputeAndGraphics             = 1
            timestampPeriod                         = 1.000000
            maxClipDistances                        = 8
            maxCullDistances                        = 8
            maxCombinedClipAndCullDistances         = 8
            discreteQueuePriorities                 = 2
            pointSizeRange[0]                       = 1.000000
            pointSizeRange[1]                       = 189.875000
            lineWidthRange[0]                       = 0.500000
            lineWidthRange[1]                       = 10.000000
            pointSizeGranularity                    = 0.125000
            lineWidthGranularity                    = 0.125000
            strictLines                             = 1
            standardSampleLocations                 = 1
            optimalBufferCopyOffsetAlignment        = 0x1
            optimalBufferCopyRowPitchAlignment      = 0x1
            nonCoherentAtomSize                     = 0x40
    VkPhysicalDeviceSparseProperties:
            residencyStandard2DBlockShape            = 1
            residencyStandard2DMultisampleBlockShape = 1
            residencyStandard3DBlockShape            = 1
            residencyAlignedMipSize                  = 1
            residencyNonResidentStrict               = 0
Device Extensions count = 38
VK_KHR_swapchain : extension revision 68
VK_KHR_16bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_dedicated_allocation : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_maintenance1 : extension revision 1
VK_KHR_maintenance2 : extension revision 1
VK_KHR_push_descriptor : extension revision 1
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 1
VK_KHR_sampler_ycbcr_conversion : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHX_device_group : extension revision 2
VK_KHX_external_memory : extension revision 1
VK_KHX_external_memory_fd : extension revision 1
VK_KHX_external_semaphore : extension revision 1
VK_KHX_external_semaphore_fd : extension revision 1
VK_KHX_multiview : extension revision 1
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_glsl_shader : extension revision 1
VK_NVX_device_generated_commands : extension revision 1
VK_NVX_multiview_per_view_attributes: extension revision 1
VkQueueFamilyProperties[0]:
    queueFlags         = GRAPHICS | COMPUTE | TRANSFER | SPARSE
    queueCount         = 16
    timestampValidBits = 64
    minImageTransferGranularity = (1, 1, 1)
VkQueueFamilyProperties[1]:
    queueFlags         = TRANSFER
    queueCount         = 1
VkPhysicalDeviceMemoryProperties:
    memoryTypeCount       = 11
    memoryTypes[0] :
            heapIndex     = 1
            propertyFlags = 0x0:
    memoryTypes[1] :
            heapIndex     = 1
    memoryTypes[2] :
            heapIndex     = 1
    memoryTypes[3] :
            heapIndex     = 1
    memoryTypes[4] :
            heapIndex     = 1
    memoryTypes[5] :
            heapIndex     = 1
    memoryTypes[6] :
            heapIndex     = 1
    memoryTypes[7] :
            heapIndex     = 0
            propertyFlags = 0x1:
                    VK_MEMORY_PROPERTY_DEVICE_LOCAL_BIT
    memoryTypes[8] :
            heapIndex     = 0
    memoryTypes[9] :
            heapIndex     = 1
            propertyFlags = 0x6:
                    VK_MEMORY_PROPERTY_HOST_VISIBLE_BIT
                    VK_MEMORY_PROPERTY_HOST_COHERENT_BIT
    memoryTypes[10] :
            heapIndex     = 1
            propertyFlags = 0xe:
                    VK_MEMORY_PROPERTY_HOST_CACHED_BIT
    memoryHeapCount       = 2
    memoryHeaps[0] :
            size          = 4294967296 (0x100000000) (4.00 GiB)
            flags:
                    VK_MEMORY_HEAP_DEVICE_LOCAL_BIT
    memoryHeaps[1] :
            size          = 12518172672 (0x2ea242800) (11.66 GiB)
            flags:
                    None
VkPhysicalDeviceFeatures:
    robustBufferAccess                      = 1
    fullDrawIndexUint32                     = 1
    imageCubeArray                          = 1
    independentBlend                        = 1
    geometryShader                          = 1
    tessellationShader                      = 1
    sampleRateShading                       = 1
    dualSrcBlend                            = 1
    logicOp                                 = 1
    multiDrawIndirect                       = 1
    drawIndirectFirstInstance               = 1
    depthClamp                              = 1
    depthBiasClamp                          = 1
    fillModeNonSolid                        = 1
    depthBounds                             = 1
    wideLines                               = 1
    largePoints                             = 1
    alphaToOne                              = 1
    multiViewport                           = 1
    samplerAnisotropy                       = 1
    textureCompressionETC2                  = 0
    textureCompressionASTC_LDR              = 0
    textureCompressionBC                    = 1
    occlusionQueryPrecise                   = 1
    pipelineStatisticsQuery                 = 1
    vertexPipelineStoresAndAtomics          = 1
    fragmentStoresAndAtomics                = 1
    shaderTessellationAndGeometryPointSize  = 1
    shaderImageGatherExtended               = 1
    shaderStorageImageExtendedFormats       = 1
    shaderStorageImageMultisample           = 1
    shaderStorageImageReadWithoutFormat     = 1
    shaderStorageImageWriteWithoutFormat    = 1
    shaderUniformBufferArrayDynamicIndexing = 1
    shaderSampledImageArrayDynamicIndexing  = 1
    shaderStorageBufferArrayDynamicIndexing = 1
    shaderStorageImageArrayDynamicIndexing  = 1
    shaderClipDistance                      = 1
    shaderCullDistance                      = 1
    shaderFloat64                           = 1
    shaderInt64                             = 1
    shaderInt16                             = 0
    shaderResourceResidency                 = 0
    shaderResourceMinLod                    = 0
    sparseBinding                           = 1
    sparseResidencyBuffer                   = 0
    sparseResidencyImage2D                  = 0
    sparseResidencyImage3D                  = 0
    sparseResidency2Samples                 = 0
    sparseResidency4Samples                 = 0
    sparseResidency8Samples                 = 0
    sparseResidency16Samples                = 0
    sparseResidencyAliased                  = 0
    variableMultisampleRate                 = 1
    inheritedQueries                        = 1
Format Properties:
FORMAT_UNDEFINED:
linearTiling FormatFeatureFlags:
None
optimalTiling FormatFeatureFlags:
None
bufferFeatures FormatFeatureFlags:
None
FORMAT_R4G4_UNORM_PACK8:
VK_FORMAT_FEATURE_SAMPLED_IMAGE_BIT
VK_FORMAT_FEATURE_BLIT_SRC_BIT
VK_FORMAT_FEATURE_SAMPLED_IMAGE_FILTER_LINEAR_BIT
VK_FORMAT_FEATURE_TRANSFER_SRC_BIT_KHR
VK_FORMAT_FEATURE_TRANSFER_DST_BIT_KHR
VK_FORMAT_FEATURE_UNIFORM_TEXEL_BUFFER_BIT
FORMAT_R4G4B4A4_UNORM_PACK16:
FORMAT_B4G4R4A4_UNORM_PACK16:
FORMAT_R5G6B5_UNORM_PACK16:
VK_FORMAT_FEATURE_COLOR_ATTACHMENT_BIT
VK_FORMAT_FEATURE_COLOR_ATTACHMENT_BLEND_BIT
VK_FORMAT_FEATURE_BLIT_DST_BIT
FORMAT_B5G6R5_UNORM_PACK16:
FORMAT_R5G5B5A1_UNORM_PACK16:
FORMAT_B5G5R5A1_UNORM_PACK16:
FORMAT_A1R5G5B5_UNORM_PACK16:
FORMAT_R8_UNORM:
VK_FORMAT_FEATURE_STORAGE_IMAGE_BIT
VK_FORMAT_FEATURE_STORAGE_TEXEL_BUFFER_BIT
VK_FORMAT_FEATURE_VERTEX_BUFFER_BIT
FORMAT_R8_SNORM:
FORMAT_R8_USCALED:
None
None
FORMAT_R8_SSCALED:
None
None
FORMAT_R8_UINT:
FORMAT_R8_SINT:
FORMAT_R8_SRGB:
None
FORMAT_R8G8_UNORM:
FORMAT_R8G8_SNORM:
FORMAT_R8G8_USCALED:
None
None
FORMAT_R8G8_SSCALED:
None
None
FORMAT_R8G8_UINT:
FORMAT_R8G8_SINT:
FORMAT_R8G8_SRGB:
None
None
None
FORMAT_R8G8B8_UNORM:
None
None
FORMAT_R8G8B8_SNORM:
None
None
FORMAT_R8G8B8_USCALED:
None
None
FORMAT_R8G8B8_SSCALED:
None
None
FORMAT_R8G8B8_UINT:
None
None
FORMAT_R8G8B8_SINT:
None
None
FORMAT_R8G8B8_SRGB:
None
None
None
FORMAT_B8G8R8_UNORM:
None
None
FORMAT_B8G8R8_SNORM:
None
None
FORMAT_B8G8R8_USCALED:
None
None
FORMAT_B8G8R8_SSCALED:
None
None
FORMAT_B8G8R8_UINT:
None
None
FORMAT_B8G8R8_SINT:
None
None
FORMAT_B8G8R8_SRGB:
None
None
None
FORMAT_R8G8B8A8_UNORM:
FORMAT_R8G8B8A8_SNORM:
FORMAT_R8G8B8A8_USCALED:
None
None
FORMAT_R8G8B8A8_SSCALED:
None
None
FORMAT_R8G8B8A8_UINT:
FORMAT_R8G8B8A8_SINT:
FORMAT_R8G8B8A8_SRGB:
None
FORMAT_B8G8R8A8_UNORM:
FORMAT_B8G8R8A8_SNORM:
FORMAT_B8G8R8A8_USCALED:
None
None
FORMAT_B8G8R8A8_SSCALED:
None
None
FORMAT_B8G8R8A8_UINT:
FORMAT_B8G8R8A8_SINT:
FORMAT_B8G8R8A8_SRGB:
None
FORMAT_A8B8G8R8_UNORM_PACK32:
FORMAT_A8B8G8R8_SNORM_PACK32:
FORMAT_A8B8G8R8_USCALED_PACK32:
None
None
FORMAT_A8B8G8R8_SSCALED_PACK32:
None
None
FORMAT_A8B8G8R8_UINT_PACK32:
FORMAT_A8B8G8R8_SINT_PACK32:
FORMAT_A8B8G8R8_SRGB_PACK32:
VK_FORMAT_FEATURE_S
it cut my msg, outputing the vulkan-smoketest:
groo@kerberos:~$ VK_LOADER_DEBUG=all vulkan-smoketest
DEBUG: Searching the following paths for manifest files: /etc/xdg/xdg-/usr/share/xsessions/plasma/vulkan/explicit_layer.d:/etc/xdg/vulkan/explicit_layer.d:/usr/share/kubuntu-default-settings/kf5-settings/vulkan/explicit_layer.d:/etc/vulkan/explicit_layer.d:/usr/share//usr/share/xsessions/plasma/vulkan/explicit_layer.d:/usr/local/share/vulkan/explicit_layer.d:/usr/share/vulkan/explicit_layer.d:/var/lib/snapd/desktop/vulkan/explicit_layer.d
DEBUG: Searching the following path for manifest files: /home/groo/.local/share/vulkan/explicit_layer.d
DEBUG: Searching the following paths for manifest files: /etc/xdg/xdg-/usr/share/xsessions/plasma/vulkan/implicit_layer.d:/etc/xdg/vulkan/implicit_layer.d:/usr/share/kubuntu-default-settings/kf5-settings/vulkan/implicit_layer.d:/etc/vulkan/implicit_layer.d:/usr/share//usr/share/xsessions/plasma/vulkan/implicit_layer.d:/usr/local/share/vulkan/implicit_layer.d:/usr/share/vulkan/implicit_layer.d:/var/lib/snapd/desktop/vulkan/implicit_layer.d
DEBUG: Searching the following path for manifest files: /home/groo/.local/share/vulkan/implicit_layer.d
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_core_validation.json, version “1.1.0”
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_object_tracker.json, version “1.1.0”
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_parameter_validation.json, version “1.1.0”
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_standard_validation.json, version “1.1.1”
INFO: Encountered meta-layer VK_LAYER_LUNARG_standard_validation
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_threading.json, version “1.1.0”
INFO: Found manifest file /usr/share/vulkan/explicit_layer.d/VkLayer_unique_objects.json, version “1.1.0”
INFO: Found manifest file /home/groo/.local/share/vulkan/implicit_layer.d/steamoverlay_i386.json, version “1.0.0”
INFO: Found manifest file /home/groo/.local/share/vulkan/implicit_layer.d/steamoverlay_x86_64.json, version “1.0.0”
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_GOOGLE_threading adding instance extension VK_EXT_debug_report
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_parameter_validation adding instance extension VK_EXT_debug_report
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_parameter_validation adding device extension VK_EXT_debug_marker
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_object_tracker adding instance extension VK_EXT_debug_report
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_object_tracker adding device extension VK_EXT_debug_marker
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_core_validation adding instance extension VK_EXT_debug_report
DEBUG: Meta-layer VK_LAYER_LUNARG_standard_validation component layer VK_LAYER_LUNARG_core_validation adding device extension VK_EXT_debug_marker
INFO: Meta-layer VK_LAYER_LUNARG_standard_validation all 5 component layers appear to be valid.
DEBUG: Searching the following paths for manifest files: /etc/xdg/xdg-/usr/share/xsessions/plasma/vulkan/icd.d:/etc/xdg/vulkan/icd.d:/usr/share/kubuntu-default-settings/kf5-settings/vulkan/icd.d:/etc/vulkan/icd.d:/usr/share//usr/share/xsessions/plasma/vulkan/icd.d:/usr/local/share/vulkan/icd.d:/usr/share/vulkan/icd.d:/var/lib/snapd/desktop/vulkan/icd.d
DEBUG: Searching the following path for manifest files: /home/groo/.local/share/vulkan/icd.d
INFO: Found ICD manifest file /etc/vulkan/icd.d/intel_icd.x86_64.json, version “1.0.0”
DEBUG: Searching for ICD drivers named /usr/lib/x86_64-linux-gnu/libvulkan_intel.so, using default dir
INFO: Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.x86_64.json, version “1.0.0”
DEBUG: Searching for ICD drivers named /usr/lib/x86_64-linux-gnu/libvulkan_radeon.so, using default dir
INFO: Found ICD manifest file /etc/vulkan/icd.d/intel_icd.i686.json, version “1.0.0”
DEBUG: Searching for ICD drivers named /usr/lib/i386-linux-gnu/libvulkan_intel.so, using default dir
ERROR: /usr/lib/i386-linux-gnu/libvulkan_intel.so: cannot open shared object file: No such file or directory
INFO: Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.i686.json, version “1.0.0”
DEBUG: Searching for ICD drivers named /usr/lib/i386-linux-gnu/libvulkan_radeon.so, using default dir
ERROR: /usr/lib/i386-linux-gnu/libvulkan_radeon.so: cannot open shared object file: No such file or directory
INFO: Found ICD manifest file /usr/share/vulkan/icd.d/intel_icd.x86_64.json, version “1.0.0”
INFO: Found ICD manifest file /usr/share/vulkan/icd.d/radeon_icd.x86_64.json, version “1.0.0”
INFO: Found ICD manifest file /usr/share/vulkan/icd.d/nvidia_icd.json, version “1.0.0”
DEBUG: Searching for ICD drivers named libGL.so.1, using default dir
DEBUG: Build ICD instance extension list
DEBUG: Instance Extension: VK_KHR_external_fence_capabilities (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_memory_capabilities (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_semaphore_capabilities (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_get_physical_device_properties2 (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_get_surface_capabilities2 (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_surface (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.25
DEBUG: Instance Extension: VK_KHR_wayland_surface (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.6
DEBUG: Instance Extension: VK_KHR_xcb_surface (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.6
DEBUG: Instance Extension: VK_KHR_xlib_surface (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.6
DEBUG: Instance Extension: VK_EXT_debug_report (/usr/lib/x86_64-linux-gnu/libvulkan_intel.so) version 0.0.8
DEBUG: Instance Extension: VK_KHR_external_memory_capabilities (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_semaphore_capabilities (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_get_physical_device_properties2 (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.1
DEBUG: Instance Extension: VK_KHR_surface (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.25
DEBUG: Instance Extension: VK_KHR_wayland_surface (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.6
DEBUG: Instance Extension: VK_KHR_xcb_surface (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.6
DEBUG: Instance Extension: VK_KHR_xlib_surface (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.6
DEBUG: Instance Extension: VK_EXT_debug_report (/usr/lib/x86_64-linux-gnu/libvulkan_radeon.so) version 0.0.8
DEBUG: Instance Extension: VK_EXT_acquire_xlib_display (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_EXT_debug_report (libGL.so.1) version 0.0.8
DEBUG: Instance Extension: VK_EXT_direct_mode_display (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_EXT_display_surface_counter (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_display (libGL.so.1) version 0.0.21
DEBUG: Instance Extension: VK_KHR_get_physical_device_properties2 (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_get_surface_capabilities2 (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_surface (libGL.so.1) version 0.0.25
DEBUG: Instance Extension: VK_KHR_xcb_surface (libGL.so.1) version 0.0.6
DEBUG: Instance Extension: VK_KHR_xlib_surface (libGL.so.1) version 0.0.6
DEBUG: Instance Extension: VK_KHX_device_group_creation (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_fence_capabilities (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHX_external_memory_capabilities (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_memory_capabilities (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHX_external_semaphore_capabilities (libGL.so.1) version 0.0.1
DEBUG: Instance Extension: VK_KHR_external_semaphore_capabilities (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_swapchain (libGL.so.1) version 0.0.68
DEBUG: Device Extension: VK_KHR_16bit_storage (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_bind_memory2 (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_descriptor_update_template (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_dedicated_allocation (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_get_memory_requirements2 (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_image_format_list (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_maintenance1 (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_maintenance2 (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_push_descriptor (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_relaxed_block_layout (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_sampler_mirror_clamp_to_edge (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_sampler_ycbcr_conversion (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_shader_draw_parameters (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_storage_buffer_storage_class (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_memory (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_memory_fd (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_semaphore (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_semaphore_fd (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_fence (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_fence_fd (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_variable_pointers (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHX_device_group (libGL.so.1) version 0.0.2
DEBUG: Device Extension: VK_KHX_external_memory (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_memory_fd (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_semaphore (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_semaphore_fd (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHX_multiview (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_EXT_blend_operation_advanced (libGL.so.1) version 0.0.2
DEBUG: Device Extension: VK_EXT_depth_range_unrestricted (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_EXT_discard_rectangles (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_EXT_display_control (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_EXT_shader_subgroup_ballot (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_EXT_shader_subgroup_vote (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_NV_dedicated_allocation (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_NV_glsl_shader (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_NVX_device_generated_commands (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_NVX_multiview_per_view_attributes (libGL.so.1) version 0.0.1
DEBUG: Device Extension: VK_KHR_swapchain (Unknown) version 0.0.68
DEBUG: Device Extension: VK_KHR_16bit_storage (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_bind_memory2 (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_descriptor_update_template (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_dedicated_allocation (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_get_memory_requirements2 (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_image_format_list (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_maintenance1 (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_maintenance2 (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_push_descriptor (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_relaxed_block_layout (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_sampler_mirror_clamp_to_edge (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_sampler_ycbcr_conversion (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_shader_draw_parameters (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_storage_buffer_storage_class (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_memory (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_memory_fd (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_semaphore (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_semaphore_fd (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_fence (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_external_fence_fd (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHR_variable_pointers (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHX_device_group (Unknown) version 0.0.2
DEBUG: Device Extension: VK_KHX_external_memory (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_memory_fd (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_semaphore (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHX_external_semaphore_fd (Unknown) version 0.0.1
DEBUG: Device Extension: VK_KHX_multiview (Unknown) version 0.0.1
DEBUG: Device Extension: VK_EXT_blend_operation_advanced (Unknown) version 0.0.2
DEBUG: Device Extension: VK_EXT_depth_range_unrestricted (Unknown) version 0.0.1
DEBUG: Device Extension: VK_EXT_discard_rectangles (Unknown) version 0.0.1
DEBUG: Device Extension: VK_EXT_display_control (Unknown) version 0.0.1
DEBUG: Device Extension: VK_EXT_shader_subgroup_ballot (Unknown) version 0.0.1
DEBUG: Device Extension: VK_EXT_shader_subgroup_vote (Unknown) version 0.0.1
DEBUG: Device Extension: VK_NV_dedicated_allocation (Unknown) version 0.0.1
DEBUG: Device Extension: VK_NV_glsl_shader (Unknown) version 0.0.1
DEBUG: Device Extension: VK_NVX_device_generated_commands (Unknown) version 0.0.1
DEBUG: Device Extension: VK_NVX_multiview_per_view_attributes (Unknown) version 0.0.1
terminate called after throwing an instance of ‘std::runtime_error’
what(): VkResult -1 returned
Aborted (core dumped)
i reverted to the 384.90 driver and applied the fix:
https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-384/+bug/1726809
and now i have a working vulkan/opengl setting.
applying the aforementioned fix with the 387.22 driver doesnt work, i still get the same segfault.
Looking at the error returned, -1, which is VK_ERROR_OUT_OF_HOST_MEMORY, and given that it reproduces on a 960M, it seems very likely to be the same bug as:
https://devtalk.nvidia.com/default/topic/1026059/vulkan/vkcreateswapchainkhr-returns-vk_error_out_of_host_memory-on-950m-with-387-22
New drivers will be available shortly.
