In our application we first create the OpenGL context (through GLFW) in the main thread and initialize a CUDA context with it. We then remove the OpenGL context from the main thread with:
glfwMakeContextCurrent(NULL)
After that the OpenGL context is made current on another thread with:
glfwMakeContextCurrent(window)
This works fine on my PC, but segfaults on the Jetson TX1 inside the glXMakeCurrent function of libGL.so.1. Which makes it seem like a bug in the libGL library.
The backtrace:
0 ?? /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf561e0f8
1 ?? /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf55f0fe2
2 ?? /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf55f17e2
3 ?? /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf55ece80
4 ?? /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf55ee4be
5 glXMakeCurrent /usr/lib/arm-linux-gnueabihf/tegra/libGL.so.1 0xf55e8618
6 _glfwPlatformMakeContextCurrent /usr/local/lib/libglfw.so.3 0xf77c441c
7 makeCurrentCUDAGLContext virtcamTegra.cpp 27 0xd2914
8 std::_Bind<void (*(GLFWwindow*, CuBackend*))(GLFWwindow*, CuBackend*)>::__call<void, , 0u, 1u>(std::tuple<>&&, std::_Index_tuple<0u, 1u>) functional 1296 0xd5a72
9 std::_Bind<void (*(GLFWwindow*, CuBackend*))(GLFWwindow*, CuBackend*)>::operator()<, void>() functional 1355 0xd5626
10 std::_Function_handler<void (), std::_Bind<void (*(GLFWwindow*, CuBackend*))(GLFWwindow*, CuBackend*)> >::_M_invoke(std::_Any_data const&) functional 2071 0xd512e
11 std::function<void ()>::operator()() const functional 2471 0xdae44
12 DedicatedTaskPool::thread_run task.cpp 619 0xda3ac
13 std::_Mem_fn<void (DedicatedTaskPool::*)()>::operator()<, void>(DedicatedTaskPool*) const functional 601 0xe0702
14 std::_Bind<std::_Mem_fn<void (DedicatedTaskPool::*)()> (DedicatedTaskPool*)>::__call<void, , 0u>(std::tuple<>&&, std::_Index_tuple<0u>) functional 1296 0xe05ac
15 std::_Bind<std::_Mem_fn<void (DedicatedTaskPool::*)()> (DedicatedTaskPool*)>::operator()<, void>() functional 1355 0xe04fe
16 std::_Bind_simple<std::_Bind<std::_Mem_fn<void (DedicatedTaskPool::*)()> (DedicatedTaskPool*)> ()>::_M_invoke<>(std::_Index_tuple<>) functional 1732 0xe038a
17 std::_Bind_simple<std::_Bind<std::_Mem_fn<void (DedicatedTaskPool::*)()> (DedicatedTaskPool*)> ()>::operator()() functional 1720 0xe026c
18 std::thread::_Impl<std::_Bind_simple<std::_Bind<std::_Mem_fn<void (DedicatedTaskPool::*)()> (DedicatedTaskPool*)> ()> >::_M_run() thread 115 0xe015e
19 ?? /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 0xf688c854
Please contact me if you need any more information.
EDIT: It of course was glfwMakeContextCurrent
