Hi there,
I am testing my OpenGL code on the TX1, and for some reason, my call to glDrawArrays leads to a seg fault. This code works perfectly on my Macbook Pro, and I’m not sure what the error is.
Basically I have a cube, am adding a texture to it, and am then drawing it! I was reading somewhere that maybe I didn’t set the context correctly, but then when I tried to set the correct GL version using glfwWindowHint (I tried versions 2.1 and 4.4), nothing changed. Can someone please help me with this? Very confused!
Here’s the relevant code:
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <GL/glew.h>
#include <GL/glut.h>
#include <GLFW/glfw3.h>
#include <glm/glm.hpp>
#include <glm/gtc/matrix_transform.hpp>
#include "controls.hpp"
#include "shader.hpp"
#include "texture.hpp"
#define WINDOW_WIDTH 1024
#define WINDOW_HEIGHT 768
#define DEPTH_Z 10000 // Virtual image plane distance
// Create pointer to window object to be used in the rest of the program
GLFWwindow* window;
using namespace std;
/* Do all the initialization necessary for GL and GL-related functions.
int GLInitialization (void)
// Initialise GLFW
if( !glfwInit() )
fprintf( stderr, "Failed to initialize GLFW\n" );
getchar();
return -1;
glfwWindowHint(GLFW_SAMPLES, 4);
// Open a window and create its OpenGL context
window = glfwCreateWindow( WINDOW_WIDTH, WINDOW_HEIGHT, "Pooja's Amazing Project!", NULL, NULL);
if( window == NULL ){
fprintf( stderr, "Failed to open GLFW window. If you have an Intel GPU, they are not 3.3 compatible. Try the 2.1 version of the tutorials.\n" );
getchar();
glfwTerminate();
return -1;
glfwMakeContextCurrent(window);
// Initialize GLEW
glewExperimental = true; // Needed for core profile
if (glewInit() != GLEW_OK) {
fprintf(stderr, "Failed to initialize GLEW\n");
getchar();
glfwTerminate();
return -1;
// Ensure we can capture the escape key being pressed below
glfwSetInputMode(window, GLFW_STICKY_KEYS, GL_TRUE);
// Hide the mouse and enable unlimited mouvement
glfwSetInputMode(window, GLFW_CURSOR, GLFW_CURSOR_DISABLED);
// Set the mouse at the center of the screen
glfwPollEvents();
glfwSetCursorPos(window, WINDOW_WIDTH/2, WINDOW_HEIGHT/2);
// Dark blue background
glClearColor(0.0f, 0.0f, 0.4f, 0.0f);
// Enable depth test
glEnable(GL_DEPTH_TEST);
// Accept fragment if it closer to the camera than the former one
glDepthFunc(GL_LESS);
// Cull triangles which normal is not towards the camera
glEnable(GL_CULL_FACE);
return 0;
int main( void )
// Setup and initialize GL libraries
if (GLInitialization() == -1)
return -1;
GLuint VertexArrayID;
glGenVertexArrays(1, &VertexArrayID);
glBindVertexArray(VertexArrayID);
// Create and compile our GLSL program from the shaders
GLuint programID = LoadShaders( "TransformVertexShader.vertexshader", "TextureFragmentShader.fragmentshader" );
// Get a handle for our "MVP" uniform
GLuint MatrixID = glGetUniformLocation(programID, "MVP");
// Load the texture
GLuint Texture = loadDDS("uvtemplate.DDS");
// Get a handle for our "myTextureSampler" uniform
GLuint TextureID = glGetUniformLocation(programID, "myTextureSampler");
// Our vertices. Tree consecutive floats give a 3D vertex; Three consecutive vertices give a triangle.
// A cube has 6 faces with 2 triangles each, so this makes 6*2=12 triangles, and 12*3 vertices
static const GLfloat g_vertex_buffer_data[] = {
-1.0f,-1.0f,-1.0f,
-1.0f,-1.0f, 1.0f,
-1.0f, 1.0f, 1.0f,
1.0f, 1.0f,-1.0f,
-1.0f,-1.0f,-1.0f,
-1.0f, 1.0f,-1.0f,
1.0f,-1.0f, 1.0f,
-1.0f,-1.0f,-1.0f,
1.0f,-1.0f,-1.0f,
1.0f, 1.0f,-1.0f,
1.0f,-1.0f,-1.0f,
-1.0f,-1.0f,-1.0f,
-1.0f,-1.0f,-1.0f,
-1.0f, 1.0f, 1.0f,
-1.0f, 1.0f,-1.0f,
1.0f,-1.0f, 1.0f,
-1.0f,-1.0f, 1.0f,
-1.0f,-1.0f,-1.0f,
-1.0f, 1.0f, 1.0f,
-1.0f,-1.0f, 1.0f,
1.0f,-1.0f, 1.0f,
1.0f, 1.0f, 1.0f,
1.0f,-1.0f,-1.0f,
1.0f, 1.0f,-1.0f,
1.0f,-1.0f,-1.0f,
1.0f, 1.0f, 1.0f,
1.0f,-1.0f, 1.0f,
1.0f, 1.0f, 1.0f,
1.0f, 1.0f,-1.0f,
-1.0f, 1.0f,-1.0f,
1.0f, 1.0f, 1.0f,
-1.0f, 1.0f,-1.0f,
-1.0f, 1.0f, 1.0f,
1.0f, 1.0f, 1.0f,
-1.0f, 1.0f, 1.0f,
1.0f,-1.0f, 1.0f
// Two UV coordinatesfor each vertex. They were created withe Blender.
static const GLfloat g_uv_buffer_data[] = {
0.000059f, 0.000004f,
0.000103f, 0.336048f,
0.335973f, 0.335903f,
1.000023f, 0.000013f,
0.667979f, 0.335851f,
0.999958f, 0.336064f,
0.336024f, 0.671877f,
0.667969f, 0.671889f,
0.668104f, 0.000013f,
0.336098f, 0.000071f,
1.000004f, 0.671847f,
0.000004f, 0.671870f,
GLuint vertexbuffer;
glGenBuffers(1, &vertexbuffer);
glBindBuffer(GL_ARRAY_BUFFER, vertexbuffer);
glBufferData(GL_ARRAY_BUFFER, sizeof(g_vertex_buffer_data), g_vertex_buffer_data, GL_STATIC_DRAW);
GLuint uvbuffer;
glGenBuffers(1, &uvbuffer);
glBindBuffer(GL_ARRAY_BUFFER, uvbuffer);
glBufferData(GL_ARRAY_BUFFER, sizeof(g_uv_buffer_data), g_uv_buffer_data, GL_STATIC_DRAW);
do{
// Clear the screen
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
// Use our shader
glUseProgram(programID);
// Compute the MVP matrix from keyboard and mouse input
computeMatricesFromInputs(window, DEPTH_Z, true);
glm::mat4 ProjectionMatrix = getProjectionMatrix();
glm::mat4 ViewMatrix = getViewMatrix();
glm::mat4 ModelMatrix = glm::mat4(1.0);
glm::mat4 MVP = ProjectionMatrix * ViewMatrix * ModelMatrix;
// Send our transformation to the currently bound shader,
// in the "MVP" uniform
glUniformMatrix4fv(MatrixID, 1, GL_FALSE, &MVP[0][0]);
// Bind our texture in Texture Unit 0
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_2D, Texture);
// Set our "myTextureSampler" sampler to user Texture Unit 0
glUniform1i(TextureID, 0);
// 1rst attribute buffer : vertices
glEnableVertexAttribArray(0);
glVertexAttribPointer(
0, // attribute. No particular reason for 0, but must match the layout in the shader.
3, // size
GL_FLOAT, // type
GL_FALSE, // normalized?
0, // stride
(void*)0 // array buffer offset
// 2nd attribute buffer : UVs
glEnableVertexAttribArray(1);
1, // attribute. No particular reason for 1, but must match the layout in the shader.
2, // size : U+V => 2
GL_FLOAT, // type
0, // stride
// Draw the triangle !
glDrawArrays(GL_TRIANGLES, 0, 12*3); // 12*3 indices starting at 0 -> 12 triangles
glDisableVertexAttribArray(0);
glDisableVertexAttribArray(1);
// Swap buffers
glfwSwapBuffers(window);
glfwPollEvents();
} // Check if the ESC key was pressed or the window was closed
while( glfwGetKey(window, GLFW_KEY_ESCAPE ) != GLFW_PRESS &&
glfwWindowShouldClose(window) == 0 );
// Cleanup VBO and shader
glDeleteBuffers(1, &vertexbuffer);
glDeleteBuffers(1, &uvbuffer);
glDeleteProgram(programID);
glDeleteTextures(1, &TextureID);
glDeleteVertexArrays(1, &VertexArrayID);
// Close OpenGL window and terminate GLFW
glfwTerminate();
return 0;
