I’m trying to build a facial recognition system, but I’m getting a Segmentation fault (core dumped) error.
Here are the software versions I’m using:
- numpy 1.19.4
- OpenCV 4.5.0 (Build)
- Dlib 19.21
- Jetpack 4.6
- CUDA 10.2
- cuDNN 8.2
I followed all the instructions from Simple accelerated face recognition - #19 by AastaLLL
My code is based on this tutorial: https://www.youtube.com/watch?v=eTf3UtnxMdw&list=PLGs0VKk2DiYxP-ElZ7-QXIERFFPkOuP4_&index=44
I triyed build dlib 19.17 19.21 19.22 19.23 and 19.24. I’m facing the same error.
Have you also tried script shared in the Simple accelerated face recognition - #19 by AastaLLL?
Does it work?
Yes!
I built OpenCV following the JetsonHacks tutorial. I followed the instructions provided in Simple accelerated face recognition - #19 by AastaLLL, but I encountered the same issue: “Segmentation fault (core dumped).”
Here are the versions of the software I’m using:
- numpy 1.19.4
- OpenCV 4.5.4 (built)
- Dlib 19.21
- Jetpack 4.6
- CUDA 10.2
- cuDNN 8.2
Now I uninstalled dlib and face recognition and reinstalled following Paul McWhorter’s instructions (without building):
sudo apt-get update
sudo apt-get install cmake libopenblas-dev liblapack-dev libjpeg-dev
sudo apt-get install python3-pip
# Swap memory setup (if applicable)
wget http://dlib.net/files/dlib-19.17.tar.bz2
tar jxvf dlib-19.17.tar.bz2
gedit cudnn-dlibapi.cpp
sudo python3 setup.py install
sudo pip3 install face_recognition
However, even after these steps, I encountered the same issue: “Segmentation fault (core dumped).”
I tried this on another SD card without building OpenCV and dlib. I successfully completed the installation and achieved 13 FPS with the following configurations:
My CPU usage ranged from 36% to 48%, and my GPU usage fluctuated between 40% and 100%.
Based on my experience, it seems that building OpenCV may not be necessary or could potentially cause conflicts when using the dlib and face_recognition libraries. Can anyone confirm this?
A possible cause is that there are multiple OpenCV installed in the environment which leads to this issue.
Do you use CUDA-based OpenCV API?
If not, you don’t need to rebuild the OpenCV from the source.
Part of the problem has been solved. I just put opencv import on the first line and it worked.
