I’m a newbie to CUDA Fortran.I have searched the forum for this error “Segmentation fault (core dumped)” and read some replies but it didn’t solve the problem.If anyone can provide me with hints or solutions to the problem,it would be grateful.
The source code is:
module precision
! Precision control
integer, parameter, public :: Single = kind(0.0) ! Single precision
integer, parameter, public :: Double = kind(0.0d0) ! Double precision
integer, parameter, public :: fp_kind = Double
!integer, parameter, public :: fp_kind = Single
module cufft
integer, public :: CUFFT_FORWARD = -1
integer, public :: CUFFT_R2C = Z'2a' ! Real to Complex (interleaved)
integer, public :: CUFFT_D2Z = Z'6a' ! Double to Double-Complex
interface cufftPlan1d
subroutine cufftPlan1d(plan, nx, type, batch) bind(C,name='cufftPlan1d')
use iso_c_binding
integer(c_int):: plan
integer(c_int),value:: nx, batch,type
end subroutine cufftPlan1d
end interface cufftPlan1d
interface cufftDestroy
subroutine cufftDestroy(plan) bind(C,name='cufftDestroy')
use iso_c_binding
integer(c_int),value:: plan
end subroutine cufftDestroy
end interface cufftDestroy
interface cufftExecD2Z
subroutine cufftExecD2Z(plan, idata, odata, direction) &
bind(C,name='cufftExecD2Z')
use iso_c_binding
use precision
integer(c_int),value:: direction
complex(fp_kind),device:: idata(*),odata(*)
end subroutine cufftExecD2Z
end interface cufftExecD2Z
end module cufft
program fft_test
use precision
use cufft
complex(fp_kind) ,allocatable:: a(:),b(:)
complex(fp_kind),device,allocatable:: a_d(:),b_d(:)
integer:: n
integer:: plan
integer :: x
n=2048
a=1
! allocate arrays on the host
allocate (a(n),b(n))
! allocate arrays on the device
allocate (a_d(n))
allocate (b_d(n))
DO x=1,1024
a(x)=a(x)+a(x)*6+1
!copy arrays to device
a_d=a
! Print initial array
print *, "Array A:"
print *, a(x)
! Initialize the plan
call cufftPlan1D(plan,n,CUFFT_D2Z,1)
! Execute FFTs
call cufftExecD2Z(plan,a_d,b_d,CUFFT_FORWARD)
! Copying results back to host
b=b_d
! Printing initial array
print *, "Array B"
print *, b(x)
!releasing memory on the host
deallocate (a,b)
!releasing memory on the device
deallocate (a_d,b_d)
! Destroying the plan
call cufftDestroy(plan)
end DO
end program fft_test
Very generically speaking a segfault indicates that there is a memory access inside the host portion of the code that is to an address that does not belong to the process. This could be an access out of bounds (e.g. the codes allocates an array of N elements, then accesses element N+1), or in the context of CUDA, an access from host code to device data other than an implicit copy. Your first task will be to narrow down which portion of the code gives rise to the error. If a debugger is available, run inside the debugger. It will stop at the point the segfault occurs. Otherwise you can place WRITEs in your code to see where the program terminates.
I have scanned through the code and did not spot any obvious problems, I am not familiar with the CUFFT bindings though. You might want to try and simplify to a program without CUFFT calls to make sure the framework works, then add calls back in one by one.
A colleague with significantly more experience with CUDA Fortran makes the following observations:
(1) Recent versions of CUDA Fortran already provide a CUFFT module which can be used with
use cufft
(2) The code as posted has a syntax error, in that module precision is not properly closed with
end module precision
This should have resulted in a syntax error reported by the compiler (and in fact does so with the CUDA Fortran we have installed here).
In addition to those mentioned above, there are a few other errors.
The array “a” is assigned a value of “1” before it is allocated.
cufft*() are functions, not subroutines, and have an integer return values.
You declare the data as complex, but are doing real-to-complex transforms. Fortran is strongly typed and does not permit such things – the compiler will complain about not finding a generic procedure. Also, CUFFT_FORWARD is used as an argument only for complex-to-complex transforms (C2C or Z2Z), for real-to-complex and complex-to-real transforms the direction is clear.
The following:
module precision
  ! Precision control
!integer, parameter, public :: fp_kind = Double
program fft_test
  use precision
  use cufft
  implicit none
integer :: n
  integer:: plan
  integer :: x, ierr
n=2048
  ! allocate arrays on the host and device
  allocate (a(n),b(n),a_d(n),b_d(n))
  a=1
DO x=1,1024
     a(x)=a(x)+a(x)*6+1
  end DO
  a_d=a
  ierr = cufftPlan1D(plan,n,CUFFT_C2C,1)
! Execute FFTs
  ierr = cufftExecC2C(plan,a_d,b_d,CUFFT_FORWARD)
  ierr = cufftExecC2C(plan,b_d,b_d,CUFFT_INVERSE)
  b=b_d
  print *, 'Max error: ', maxval(abs(a-b/n))
!releasing memory on the host and device
  deallocate (a,b,a_d,b_d)
  ierr = cufftDestroy(plan)
compiles and runs fine:
~/Desktop $ pgf90 cufftForum.cuf -lcufft
~/Desktop $ ./a.out
 Max error:    3.4385216E-06
I changed it to single precision since I am using a laptop.
Thank you.The code is executing well.
@fortran
@njuffa
I can think i have an older version on the machine and it doesn’t have a built-in cufft module.
I went back and checked and i had actually missed the “end module precision” while writing the code here.
But now the problem that i’m facing is that the results of the FFT that are being published are wrong.I checked the results by coding for the same program in IDL and the CUDA results are showing a lot of deviation.
Any insights into why this is happening would be of great help!
The code is as:
module precision
! Precision control
module cufft
use iso_c_binding
use iso_c_binding
interface cufftExecR2C
subroutine cufftExecR2C(plan, idata, odata, direction) &
bind(C,name='cufftExecR2C')
use iso_c_binding
use precision
end subroutine cufftExecR2C
end interface cufftExecR2C
end module cufft
program fft_test
use precision
use cufft
real(fp_kind) ::x1
real,parameter :: pi=3.1415
real(fp_kind),allocatable ::a (:)
complex(fp_kind) ,allocatable:: b(:)
complex(fp_kind),device,allocatable:: b_d(:)
real(fp_kind),device,allocatable :: a_d(:)
integer:: n,plan,i
n=1024
allocate (a_d(n))
allocate (b_d(n))
DO x=1,1024
     x1=i*pi/180
     a(i)=sin(x1)+cos(x1)
  end DO
a_d=a
print *, "Array A:"
print *, a
call cufftPlan1D(plan,n,CUFFT_R2C,1)
! Execute FFTs
call cufftExecR2C(plan,a_d,b_d,CUFFT_FORWARD)
! Copy results back to host
b=b_d
print *, "Array B"
print *, b
!release memory on the host
deallocate (a,b)
!release memory on the device
! Destroy the plan
This code shouldn’t compile, I am not sure how you are getting results.
In the cufftExecR2C() interface both arrays are declared as complex, but for a real-to-complex transform the input array should be real.
Also, real-to-complex/complex-to-real transforms shouldn’t have CUFFT_FORWARD as an argument.
If you want to have the functionality of switching between single and double precision via changing only fp_kind, you can define a generic interface for cufftExec that will resolve to either cufftExecR2C if the arrays are single precision or cufftExecD2Z when they are double precision:
interface cufftExec
     subroutine cufftExecR2C(plan, idata, odata) &
       use iso_c_binding
       use precision
       integer(c_int), value:: plan
       real(Single), device :: idata(*)
       complex(Single), device:: odata(*)
subroutine cufftExecD2Z(plan, idata, odata) &
       use iso_c_binding
       use precision
       real(Double),device:: idata(*)
       complex(Double),device:: odata(*)
In the main code you would just call cufftExec after initializing the appropriate plan:
if (kind_fp == Single) then
  else
  end if
  call cufftExec(plan,a_d,b_d)
Hope this helps.
