I tried to implement RTSP receiver and resender.
My program achieved receive RTSP packets.
They are elementary stream.
I need to set decoder. But I call dqEvent(), it occurs segmentation fault.
And when I comment out dqEvent, query_and_set_capture() is segmentation fault.
When do I need dqEvent() and query_and_set_capture()?
How to initialize output_plane buffer of decoder with empty buffer ?
For ensuring the received and depayed h264/h265 stream is decode-able, you may save it to a file and check if the file can be decoded through the samples.
In your application, you should receive RTSP packets and depay the packets to h264 stream. Is it possible to save it to a file? And then try to decode it through samples, to check if the h264 stream is valid.
We would suggest follow the samples to develop your use-case. The samples are tested/verified in each release and should work fine, if you follow the call flows.
If you suspect it is something wrong in our release, please share a way(patch and steps to run reference samples) so that we can reproduce it and do investigation.
