Hi, I am encountering a segmentation fault error when running the apply_binaries.sh script to install the Jetson Orin NX BSP on a fresh Ubuntu 24.04 server PC (B) using Docker. The script fails during the installation of the libc-bin package, with qemu-aarch64-static reporting signal 11 (Segmentation Fault). Below is the error log:
xuzhenhua@ubuntu2204-docker:/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/rootfs
Installing extlinux.conf into /boot/extlinux in target rootfs
/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Skipping installation of nvidia-igx-systemd-reboot-hooks_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-apt-source_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-config_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-tools_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-x11_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-factory-service_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-igx-bootloader_36.3.0-20240506102626_arm64.deb ....
Skipping installation of nvidia-l4t-jetson-orin-nano-qspi-updater_36.3.0-20240506102626_arm64.deb ....
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/rootfs /mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra
Installing BSP Debian packages in /mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/rootfs
Selecting previously unselected package nvidia-l4t-core.
(Reading database ... 166575 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_36.3.0-20240506102626_arm64.deb ...
Pre-installing... skip compatibility checking.
Unpacking nvidia-l4t-core (36.3.0-20240506102626) ...
Setting up nvidia-l4t-core (36.3.0-20240506102626) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
qemu: uncaught target signal 11 (Segmentation fault) - core dumped
dpkg: error processing package libc-bin (--install):
installed libc-bin package post-installation script subprocess returned error exit status 139
Errors were encountered while processing:
libc-bin
xuzhenhua@ubuntu2204-docker:/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra$ sudo ./apply_binaries.sh //run again
mknod: /mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra/rootfs/dev/random: File exists
xuzhenhua@ubuntu2204-docker:/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra$ uname -r
6.8.0-49-generic
xuzhenhua@ubuntu2204-docker:/mnt/data/xuzhenhua/work/nvidia/orin-nx/jetson-36p3-git/Linux_for_Tegra$ qemu-aarch64-static --version
qemu-aarch64 version 6.2.0 (Debian 1:6.2+dfsg-2ubuntu6.24)
Copyright (c) 2003-2021 Fabrice Bellard and the QEMU Project developers
I tried running the script again, but the error persists. The following additional information might help with diagnosing the issue:
Host System (PC B, new Ubuntu 24.04):
- Docker run Ubuntu 22.04
- Kernel version: 6.8.0-49-generic
- QEMU version: qemu-aarch64 6.2.0
Working System (PC A, older Ubuntu 20.04):
- Kernel version: 5.15.0-125-generic
On PC A, the script runs without any issues, but on PC B, I continue to face the segmentation fault error. The Docker environment on both systems is the same, running Ubuntu 22.04 for the container.
Steps I’ve Already Tried:
- I confirmed that QEMU is properly installed (qemu-aarch64-static).
- I re-ran the script multiple times, but the issue persists.
- No issues with disk space or permissions.
- I re-ran on Ubuntu 24.04 server PC (B) without docker, but the issue persists.
