Hi et legacy crashes due to libnvidia-glcore.so as it seems:
card: GeForce GTX 550 Ti
(gdb) r
(gdb) r
Starting program: /usr/bin/etl
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
ET Legacy v2.76-468-g990f573 linux-x86_64 Aug 12 2019 DEBUG
Zone megs: 64
Info: fs_game now defaults to 'legacy' mod instead of 'etmain'
----- FS_Startup -----
Current search path:
/home/user/.etlegacy/legacy
/home/user/.etlegacy/legacy/tm_sounds_fixup_v1r0.pk3 (21 files)
/home/user/.etlegacy/legacy/pak3_v2.76.pk3 (1107 files)
/home/user/.etlegacy/legacy/pak3_v2.75.pk3 (951 files)
/home/user/.etlegacy/legacy/etl_bin_v2.76.pk3 (8 files)
/home/user/.etlegacy/legacy/etl_bin_v2.75.pk3 (8 files)
/usr/lib/etlegacy/legacy
/usr/lib/etlegacy/legacy/pak3_v2.76_dirty.pk3 (1168 files)
/usr/lib/etlegacy/legacy/etl_bin_v2.76_dirty.pk3 (2 files)
/home/user/.etlegacy/etmain
/home/user/.etlegacy/etmain/Warbell.pk3 (242 files)
/home/user/.etlegacy/etmain/venice.pk3 (330 files)
/home/user/.etlegacy/etmain/transmitter.pk3 (143 files)
/home/user/.etlegacy/etmain/tc_base.pk3 (63 files)
/home/user/.etlegacy/etmain/sw_oasis_b3.pk3 (45 files)
/home/user/.etlegacy/etmain/sw_goldrush_te.pk3 (48 files)
/home/user/.etlegacy/etmain/supply.pk3 (44 files)
/home/user/.etlegacy/etmain/sp_delivery_te.pk3 (51 files)
/home/user/.etlegacy/etmain/snatch3.pk3 (34 files)
/home/user/.etlegacy/etmain/pirates.pk3 (154 files)
/home/user/.etlegacy/etmain/parisbastille_b3.pk3 (116 files)
/home/user/.etlegacy/etmain/missile_b4.pk3 (89 files)
/home/user/.etlegacy/etmain/lighthouse.pk3 (110 files)
/home/user/.etlegacy/etmain/italyfp2.pk3 (325 files)
/home/user/.etlegacy/etmain/et_mor2_night_final.pk3 (92 files)
/home/user/.etlegacy/etmain/et_ice.pk3 (61 files)
/home/user/.etlegacy/etmain/et_beach.pk3 (177 files)
/home/user/.etlegacy/etmain/etl_frostbite_v5.pk3 (151 files)
/home/user/.etlegacy/etmain/etl_frostbite_v4.pk3 (161 files)
/home/user/.etlegacy/etmain/erdenberg_b2.pk3 (79 files)
/home/user/.etlegacy/etmain/el_kef_final.pk3 (38 files)
/home/user/.etlegacy/etmain/dubrovnik_final.pk3 (186 files)
/home/user/.etlegacy/etmain/capuzzo_b1.pk3 (215 files)
/home/user/.etlegacy/etmain/caen2.pk3 (85 files)
/home/user/.etlegacy/etmain/bremen_final.pk3 (100 files)
/home/user/.etlegacy/etmain/breakout_371.pk3 (103 files)
/home/user/.etlegacy/etmain/braundorf_final.pk3 (76 files)
/home/user/.etlegacy/etmain/base47.pk3 (67 files)
/home/user/.etlegacy/etmain/adlernest.pk3 (113 files)
/usr/lib/etlegacy/etmain
/usr/lib/etlegacy/etmain/pak2.pk3 (22 files)
/usr/lib/etlegacy/etmain/pak1.pk3 (10 files)
/usr/lib/etlegacy/etmain/pak0.pk3 (3725 files)
10520 files in pk3 files
Creating PID file 'profiles/user/profile.pid'
SQLite3 libversion 3.29.0 - database URI 'etl.db' - in file
... loading existing database '/home/user/.etlegacy/etl.db'
... database file '/home/user/.etlegacy/etl.db' loaded
SQLite3 ETL: DB init #2/home/user/.etlegacy/etl.db in [1] ms - autocommit 1
SQLite3 ETL: DB schema version #2 is up to date!
Warning: etl_pakmeta.txt was not found.
execing default.cfg
execing profiles/user/etconfig.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
Not logging server attacks to disk.
----- Client Initialization -----
----- Initializing Renderer ----
Trying to load "librenderer_opengl1_x86_64.so" from "/usr/bin"...
Trying to load "librenderer_opengl1_x86_64.so" from "/usr/lib/etlegacy"...
ETKEY found.
Available client translations: Bulgarian Czech German Greek English Esperanto Spanish Finnish French Hungarian Italian Korean Dutch Norwegian Polish Portuguese Romanian Russian Slovak Slovenian Serbian Swedish Turkish
Available mod translations: Bulgarian Czech German Greek English Esperanto Spanish Finnish French Hungarian Italian Korean Dutch Norwegian Polish Portuguese Romanian Russian Slovak Slovenian Serbian Swedish Turkish
Language set to English
----- Client Initialization Complete -----
----- R_Init -----
SDL build version 2.0.10 - link version 2.0.10.
SDL initialized driver "x11"
Initializing OpenGL display
Estimated display aspect: 1.778
...setting mode -2: 1920x1080
Using 24 color bits, 24 depth, 0 stencil display.
Available modes [13]: '1280x720 1600x900 1920x1080 1280x800 1440x900 1680x1050 720x480 640x480 800x600 1024x768 1152x864 720x576 1280x1024'
Using GLEW 2.1.0
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce GTX 550 Ti/PCIe/SSE2
GL_VERSION: 4.6.0 NVIDIA 390.116
Using vanilla renderer
Initializing OpenGL extensions
...found OpenGL extension - GL_EXT_texture_compression_s3tc
...found OpenGL extension - GL_EXT_texture_env_add
...found OpenGL extension - GL_ARB_multitexture
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(24-bits) Z(24-bit) stencil(0-bits)
MODE: -2, SCREEN: 1920 x 1080 fullscreen (ratio 1.7778) Hz:N/A
GAMMA: hardware w/ 0 overbright bits
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 32
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
Program received signal SIGSEGV, Segmentation fault.
0x00007fffdd282468 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
(gdb) bt
#0 0x00007fffdd282468 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#1 0x00007fffdcd730e6 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#2 0x00007fffdcd7dcfa in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#3 0x00007fffdceded13 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#4 0x00007fffdceaa7e7 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#5 0x00007fffdceaef04 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#6 0x00007fffdceb2c08 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#7 0x00007fffdced0947 in ?? () from /usr/lib/libnvidia-glcore.so.390.116
#8 0x00007fffe14efa97 in Upload32 (noCompress=<optimized out>, pUploadHeight=0x55555813a0ec, pUploadWidth=0x55555813a0e8, format=0x55555813a0f8, lightMap=qfalse, picmip=qfalse, mipmap=<optimized out>, height=8, width=8, data=0x7fffffffcfd0)
at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_image.c:771
#9 R_CreateImage (name=<optimized out>, name@entry=0x7fffe15222c7 "*white", pic=pic@entry=0x7fffffffcfd0 '77' <repeats 200 times>..., width=width@entry=8, height=height@entry=8, mipmap=mipmap@entry=qfalse, allowPicmip=allowPicmip@entry=qfalse, wrapClampMode=10497)
at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_image.c:960
#10 0x00007fffe14efd3b in R_CreateBuiltinImages () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_image.c:1320
#11 0x00007fffe14f09f1 in R_InitImages () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_image.c:1460
#12 0x00007fffe14f2db1 in R_Init () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_init.c:1206
#13 0x00007fffe14fb647 in RE_BeginRegistration (glconfigOut=0x5555569104f4 <cls+1525076>) at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/renderer/tr_model.c:1839
#14 0x00005555555b35d0 in CL_InitRenderer () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/client/cl_main.c:2483
#15 0x00005555555b3675 in CL_StartHunkUsers () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/client/cl_main.c:2514
#16 0x00005555555b37e8 in CL_StartHunkUsers () at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/client/cl_main.c:2507
#17 0x000055555557bd56 in Com_Init (commandLine=0x7fffffffd8c0 "") at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/qcommon/common.c:3042
#18 0x000055555556a414 in main (argc=1, argv=0x7fffffffddc8) at /tmp/yaourt-tmp-user/aur-etlegacy-git/src/etlegacy/src/sys/sys_main.c:1054
pacman -Q nvidia-390xx
nvidia-390xx 390.116-44
pacman -Q nvidia-390xx-utils
nvidia-390xx-utils 390.116-1
What kind of information is needed - maybe it’s a bug that’s fixable?
