I am using deep-stream to run detector on the image, and than I want to send the cropped images with your kafka plugin.
I see that in the plugin I can send only metadata, and that the image is not passed on.
how can I do that?
thanks
You can modify sources/gst-plugins/gst-nvmsgconv/gstnvmsgconv.c
gst_nvmsgconv_transform_ip()
Get yuv buffer and metadata, then create NvDsEventMsgMeta
I think cropped image can be saved in NvDsEventMsgMeta->extMsg
In order to send cropped image with NvDsEventMsgMeta, what is the best way to send with json? Any suggestion to do so?
