I have a stored in global memory of the GPU a image, this was the result of a previous process, now I need to do bilinear interpolation and want to use texture memory because it is very easy to use.
Usually when I have the image on the CPU I use the cudaMemcpyToArray function, but for this case I do not know what function to use
If the data is already on the GPU, there is no need to copy it. You just need to pass a pointer to that data to the CUDA kernel that processes it. If the image you are referring to is the output of a graphics pipeline, you would have to look into the documentation for DX or OpenGL interop.
