Fellow CUDA enthusiasts,
I have read the following in the CUDA 2.1 FAQ.
Is it possible to write the results from a kernel directly to texture (for multi-pass algorithms)
Not currently, but you can copy from global memory back to the array (texture). Device to device memory copies are fast.
I am currently running CUDA 2.0 due to some device level limitations. I need to work with large images and process them through different kernels. The input image is an array bound to a texture. When processed through the first kernel I was hoping to write out the modified image (stored in global memory) into another texture. This would enable faster access since it forms the input to the next kernel. I have not been able to find a way to do this. When I bind the modified image array in global memory to a texture I get a run time error. I am pretty sure that I am doing something clumsy. Could anyone recommend a way to write the kernel output back a texture? Any references would be a great help too. I hope I am making my problem clear enough.
Thanks for your help!
xuberance
