Hello, I ported my sensor driver to 36.3.0 and it loaded successfully, but there was no video device. I ported it from 35.5.0 and made some appropriate modifications
Maybe reference to below topic to check if the same error.
Hello ShaneCCC,
I use jetson orinnx16GB 36.3.0, I want to know whether the device tree is loaded from the kernel_tegra234-p3768-0000+p3767-0000-nv.dtb file, whether there are other places will also, I checked my device tree and there was no imx219 related content, but the system actually loaded the relevant part, which was strange
dts.txt (315.2 KB)
Check the /boot/extlinux/extlinux.conf for the FDT.
Hello,ShaneCCC
I compared the difference with the previous driver and found that this place has been modified, and then the video device does not bind operation, is this the reason?
Hello ShaneCCC,
how to close imx219 ?
Maybe remove the imx219 and rebuild the device tree to replace the dtb file that FDT define.
Hello ShaneCCC,
However, I decompiled the device tree on the board to check and did not find the contents of imx219, but there are related contents under /proc/device-tree, I don’t understand, where should I modify?
Hello ShaneCCC,
I found that I stopped here after adding the print information, any good suggestions
emmm, Can someone answer my question
