Separating CUDA and C++ files
I am trying to separate CUDA .cu and C++ .cpp files. I have the following 2 files:
main.cpp
#include <iostream>
using namespace std;
void test1();
int main()
	test1();
	cout << "EXIT APPLICATION" << endl;
	cin.get();
	return 0;
test.cu
//#include <iostream>
//using namespace std;
__global__ void test(int A[])
	int tid = threadIdx.x;
	A[tid] = 10;
void test1()
	int* a;
	int b[5] = {0,0,0,0,0};
	cudaMalloc((void**)&a, 5 * sizeof(int));
	cudaMemcpy(a,b,5 * sizeof(int), cudaMemcpyHostToDevice);
	test<<<1,5>>>(a);
	cudaMemcpy(b,a, 5 * sizeof(int), cudaMemcpyDeviceToHost);
	/*for(int i=0; i < 5; i++)
		cout << b[i] << endl;
The above code compiles fine. However, when im trying to PRINT the results of array “b” in test.cu file, it gives me errors!. (Thats why its commented out). How should i split this code properly so that it compiles fine and i am able to do anything i want with the results im getting from GPU.
Error im getting when uncommented code is run:
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: class std::basic_ostream<char,struct std::char_traits<char> > & __thiscall std::basic_ostream<char,struct std::char_traits<char> >::operator<<(class std::basic_ostream<char,struct std::char_traits<char> > & (__cdecl*)(class std::basic_ostream<char,struct std::char_traits<char> > &))" (??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEAAV01@P6AAAV01@AAV01@@Z@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl std::endl(class std::basic_ostream<char,struct std::char_traits<char> > &)" (?endl@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@1@AAV21@@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: void __thiscall std::basic_ios<char,struct std::char_traits<char> >::setstate(int,bool)" (?setstate@?$basic_ios@DU?$char_traits@D@std@@@std@@QAEXH_N@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: int __thiscall std::ios_base::width(int)" (?width@ios_base@std@@QAEHH@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: static bool __cdecl std::char_traits<char>::eq_int_type(int const &,int const &)" (?eq_int_type@?$char_traits@D@std@@SA_NABH0@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: static int __cdecl std::char_traits<char>::eof(void)" (?eof@?$char_traits@D@std@@SAHXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: int __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::sputc(char)" (?sputc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEHD@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: class std::basic_streambuf<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::rdbuf(void)const " (?rdbuf@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEPAV?$basic_streambuf@DU?$char_traits@D@std@@@2@XZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: char __thiscall std::basic_ios<char,struct std::char_traits<char> >::fill(void)const " (?fill@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEDXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: int __thiscall std::ios_base::flags(void)const " (?flags@ios_base@std@@QBEHXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: int __thiscall std::ios_base::width(void)const " (?width@ios_base@std@@QBEHXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: static unsigned int __cdecl std::char_traits<char>::length(char const *)" (?length@?$char_traits@D@std@@SAIPBD@Z) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: class std::basic_ostream<char,struct std::char_traits<char> > & __thiscall std::basic_ostream<char,struct std::char_traits<char> >::flush(void)" (?flush@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEAAV12@XZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: class std::basic_ostream<char,struct std::char_traits<char> > * __thiscall std::basic_ios<char,struct std::char_traits<char> >::tie(void)const " (?tie@?$basic_ios@DU?$char_traits@D@std@@@std@@QBEPAV?$basic_ostream@DU?$char_traits@D@std@@@2@XZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: bool __thiscall std::ios_base::good(void)const " (?good@ios_base@std@@QBE_NXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: void __thiscall std::basic_ostream<char,struct std::char_traits<char> >::_Osfx(void)" (?_Osfx@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAEXXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::_Lock(void)" (?_Lock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: void __thiscall std::basic_streambuf<char,struct std::char_traits<char> >::_Unlock(void)" (?_Unlock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) already defined in test.cu.obj
1>msvcprtd.lib(MSVCP90D.dll) : error LNK2005: "public: class std::locale::facet * __thiscall std::locale::facet::_Decref(void)" (?_Decref@facet@locale@std@@QAEPAV123@XZ) already defined in test.cu.obj
1>libcpmt.lib(locale0.obj) : error LNK2005: "void __cdecl _AtModuleExit(void (__cdecl*)(void))" (?_AtModuleExit@@YAXP6AXXZ@Z) already defined in msvcprtd.lib(locale0_implib.obj)
1>libcpmt.lib(locale0.obj) : error LNK2005: "private: static class std::locale::_Locimp * __cdecl std::locale::_Getgloballocale(void)" (?_Getgloballocale@locale@std@@CAPAV_Locimp@12@XZ) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(locale0.obj) : error LNK2005: __Fac_tidy already defined in msvcprtd.lib(locale0_implib.obj)
1>libcpmt.lib(locale0.obj) : error LNK2005: "private: static void __cdecl std::locale::facet::facet_Register(class std::locale::facet *)" (?facet_Register@facet@locale@std@@CAXPAV123@@Z) already defined in msvcprtd.lib(locale0_implib.obj)
1>libcpmt.lib(locale0.obj) : error LNK2005: "public: static void __cdecl std::_Locinfo::_Locinfo_dtor(class std::_Locinfo *)" (?_Locinfo_dtor@_Locinfo@std@@SAXPAV12@@Z) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(locale0.obj) : error LNK2005: "public: static void __cdecl std::_Locinfo::_Locinfo_ctor(class std::_Locinfo *,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_Locinfo_ctor@_Locinfo@std@@SAXPAV12@ABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@2@@Z) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(xmutex.obj) : error LNK2005: "public: void __thiscall std::_Mutex::_Lock(void)" (?_Lock@_Mutex@std@@QAEXXZ) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(xmutex.obj) : error LNK2005: "public: void __thiscall std::_Mutex::_Unlock(void)" (?_Unlock@_Mutex@std@@QAEXXZ) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(xlock.obj) : error LNK2005: "public: __thiscall std::_Lockit::_Lockit(int)" (??0_Lockit@std@@QAE@H@Z) already defined in msvcprtd.lib(MSVCP90D.dll)
1>libcpmt.lib(xlock.obj) : error LNK2005: "public: __thiscall std::_Lockit::~_Lockit(void)" (??1_Lockit@std@@QAE@XZ) already defined in msvcprtd.lib(MSVCP90D.dll)
1>LIBCMT.lib(invarg.obj) : error LNK2005: __invoke_watson already defined in MSVCRTD.lib(MSVCR90D.dll)
1>LIBCMT.lib(setlocal.obj) : error LNK2005: __configthreadlocale already defined in MSVCRTD.lib(MSVCR90D.dll)
1>LIBCMT.lib(lconv.obj) : error LNK2005: _localeconv already defined in MSVCRTD.lib(MSVCR90D.dll)
1>LIBCMT.lib(tidtable.obj) : error LNK2005: __encode_pointer already defined in MSVCRTD.lib(MSVCR90D.dll)
1>LIBCMT.lib(tidtable.obj) : error LNK2005: __decode_pointer already defined in MSVCRTD.lib(MSVCR90D.dll)
Thanks for any help!!!
I guess u need to include the *.cu file. Because u r only calling a function definition, which wasn’t implemented in ur *.cpp file.
your code is correct, you just need to compile your *.cu and *.cpp with the same runtime library.
In visual studio:
  1. Right click on your *.cu file.
  2. Select “properties”
  3. Under “CUDA Runtime API”, select “Host”
  4. Switch “Runtime library” from “Multi-Threaded /MT” to “Multi-Threaded DLL /DLL”
(You don’t have to include the *.cu file from your *.cpp)
Good luck!
Hy,
Me I have the messages:
1>uafxcwd.lib(afxmem.obj) : error LNK2005: “void * __cdecl operator new(unsigned int)” (??2@YAPAXI@Z) déjà défini(e) dans MSVCRTD.lib(MSVCR100D.dll)
1>uafxcwd.lib(afxmem.obj) : error LNK2005: “void __cdecl operator delete(void *)” (??3@YAXPAX@Z) déjà défini(e) dans MSVCRTD.lib(MSVCR100D.dll)
1>uafxcwd.lib(afxmem.obj) : error LNK2005: “void * __cdecl operator new(unsigned int)” (??_U@YAPAXI@Z) déjà défini(e) dans msvcprtd.lib(newaop_s.obj)
1>uafxcwd.lib(afxmem.obj) : error LNK2005: “void __cdecl operator delete(void *)” (??_V@YAXPAX@Z) déjà défini(e) dans MSVCRTD.lib(MSVCR100D.dll)
1>uafxcwd.lib(appcore.obj) : error LNK2001: symbole externe non résolu ___wargv
1>uafxcwd.lib(appcore.obj) : error LNK2001: symbole externe non résolu ___argc
My project is an MDI Visual 2010 project, witch have good compiling without CUDA.
Can you help me ?
Bmoraut
