Here is the source code for the loopback test so that you can reproduce the issue, simply compile it with gcc. (We had to use ttyTHS2 and ttyS0 on the development board with headers J17 and J21, but with USB to serial converters you can simply use ttyUSB0 and ttyUSB1 or whatever your devices show up as.)
/* Program to test serial port throughput */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <inttypes.h>
#include <time.h>
#include <fcntl.h> // Required for open()
#include <unistd.h> // Required for read(), write(), close()
#include <termios.h> // Required for tcgetattr(), cfsetispeed(), cfsetospeed(), tcflush()
#include <errno.h> // Require for errno
#include <unistd.h> // Required for error codes, among other things
#include <poll.h> // Required for poll()
#include <sys/types.h>
#include <sys/stat.h>
#define VERSION_MAJOR 1
#define VERSION_MINOR 0
#define DEVLENGTH 128
#define BAUDLENGTH 32
#define RX 1
#define TX 2
static const char *optString = "vd:b:rt";
typedef struct {
int verbose; /* enable verbose output */
char devpath[DEVLENGTH]; /* -d serial device */
int baudrate; /* baudrate to use */
int sermode; /* serial mode RX or TX */
int fd; /* file descriptor */
} Settings_t;
/* parse_args() - Parse command line arguments and set */
/* values as necessary. */
/* parameters: argc = argument count, argv = argument values */
void parse_args(int argc, char *argv[], Settings_t *settings)
int opt = 0;
/* set default device path */
strncpy(settings->devpath, "/dev/ttyUSB0", DEVLENGTH);
/* set default baud rate */
settings->baudrate = 9600;
opt = getopt( argc, argv, optString );
while( opt != -1 ) {
switch( opt ) {
case 'v':
// turn on verbose mode
settings->verbose = 1;
break;
case 'd':
// sets the device path
strncpy(settings->devpath, optarg, DEVLENGTH);
break;
case 'b':
// sets the baud rate
settings->baudrate = atoi(optarg);
break;
case 'r':
// sets to serial receive mode
settings->sermode = RX;
break;
case 't':
// sets to serial transmit mode
settings->sermode = TX;
break;
case 'h':
case '?':
printf("sertest version %d.%d\n", VERSION_MAJOR, VERSION_MINOR);
printf("usage: ./%s [-v] [-d device] [-b baud] -t|-r\n", argv[0]);
printf(" -v enables verbose mode\n");
printf(" -d <devicename> sets the serial device\n");
printf(" -b <baud> sets the baud rate\n");
printf(" -t sets mode to transmit\n");
printf(" -r sets mode to receive\n");
exit( EXIT_FAILURE );
break;
default:
/* You won't actually get here. */
break;
if (settings->verbose) {
printf("Arguments:\n");
printf(" -v: %d\n", settings->verbose);
printf(" -d: %s\n", settings->devpath);
printf(" -b: %d\n", settings->baudrate);
printf(" -r/t: %d\n", settings->sermode);
/* openport() - opens the selected serial port and gets a */
int openport(Settings_t *settings)
settings->fd = open(settings->devpath, O_RDWR | O_NOCTTY | O_NDELAY);
if (settings->fd <= 0) {
char errorString[0xFF];
strerror_r(errno, errorString, sizeof(errorString));
fprintf(stderr, "Open device failed: Unable to open device file %s. Error: %s\n", settings->devpath, errorString);
return -1;
} else {
fprintf(stderr, "Got file descriptor: %d\n", settings->fd);
// Reset the serial device file descriptor for non-blocking read / write
fcntl(settings->fd, F_SETFL, 0);
return 0;
/* configureport() - configures the selected serial port */
int configureport(Settings_t *settings)
// Modify the settings on the serial device (baud rate, 8n1, receiver enabled, ignore modem status, no flow control) and apply them
struct termios deviceOptions;
memset (&deviceOptions, 0, sizeof deviceOptions);
tcgetattr(settings->fd, &deviceOptions);
/* Set the baud rates... */
speed_t MyBaud;
switch (settings->baudrate) {
case 9600:
MyBaud = B9600;
break;
case 57600:
MyBaud = B57600;
break;
case 115200:
MyBaud = B115200;
break;
case 230400:
MyBaud = B230400;
break;
case 460800:
MyBaud = B460800;
break;
case 921600:
MyBaud = B921600;
break;
case 1000000:
MyBaud = B1000000;
break;
case 2000000:
MyBaud = B2000000;
break;
case 3000000:
MyBaud = B3000000;
break;
default:
MyBaud = B9600;
//cfsetispeed(&deviceOptions, settings->baudrate);
//cfsetospeed(&deviceOptions, settings->baudrate);
cfsetispeed(&deviceOptions, MyBaud);
cfsetospeed(&deviceOptions, MyBaud);
// Set character length
deviceOptions.c_cflag &= ~CSIZE; // Mask the character size bits
deviceOptions.c_cflag |= CS8;
// No parity
deviceOptions.c_cflag &= ~PARENB;
deviceOptions.c_cflag |= PARODD;
// Stick parity flag
deviceOptions.c_cflag |= CMSPAR;
// ignores parity errors and passes bytes regardless
deviceOptions.c_iflag |= (IGNPAR);
//causes parity errors to be 'marked' in the input stream using special characters.
//If IGNPAR is enabled, a NUL character (0x00) is sent to your program before every character with a parity error.
//Otherwise, a DEL (0x7F) and NUL character is sent along with the bad character.
deviceOptions.c_iflag |= (PARMRK);
//enable checking and stripping of the parity bit
//NOTE: PARMRK and INPCK are exclusive of each other
//options.c_iflag |= (INPCK);
//options.c_iflag |= (ISTRIP);
// One stop bit
deviceOptions.c_cflag &= ~CSTOPB;
/* No hardware flow control */
deviceOptions.c_cflag &= ~CRTSCTS;
// Raw input, no echo
deviceOptions.c_lflag &= ~(ECHO | ECHOE | ECHONL | ICANON | IEXTEN | ISIG);
deviceOptions.c_iflag &= ~(IGNBRK | BRKINT | PARMRK | ISTRIP
| INLCR | IGNCR | ICRNL | IXON | IXOFF | IXANY | INPCK );
// Raw output
deviceOptions.c_oflag &= ~(OCRNL | ONLCR | ONLRET |
ONOCR | OFILL | OLCUC | OPOST);
// Wait timeout for each character
deviceOptions.c_cc[VMIN] = 1;
deviceOptions.c_cc[VTIME] = 0;
/* Enable the receiver and set local mode... */
deviceOptions.c_cflag |= (CLOCAL | CREAD);
tcflush(settings->fd, TCIFLUSH);
if (tcsetattr(settings->fd, TCSANOW, &deviceOptions) != 0) {
close(settings->fd);
fprintf(stderr, "Create failed: Unable to set options on device. Error: %s\n", errorString);
return -1;
printf("Configured serial device file descriptor for 8n1 and no flow control: %s\n", settings->devpath);
return 0;
/* readBytes() - reads bytes from the selected serial port */
ssize_t readBytes(int deviceFileDescriptor, void* destination, ssize_t size)
ssize_t bytesRead = 0;
while (bytesRead < (ssize_t)size) {
ssize_t result = read(deviceFileDescriptor, destination + bytesRead, size - bytesRead);
if (result <= 0 && errno != EWOULDBLOCK) {
fprintf(stderr, "Failed to read from device descriptor. Error: %s\n", errorString);
return result;
if (result <= 0 && errno != EAGAIN) {
fprintf(stderr, "Error: %s\n", errorString);
return result;
bytesRead += result;
return bytesRead;
/* writeBytes() - writes bytes to the selected serial port */
ssize_t writeBytes(int deviceFileDescriptor, const void* source, ssize_t size) {
ssize_t bytesWritten = 0;
while (bytesWritten < size) {
ssize_t result = write(deviceFileDescriptor, source + bytesWritten, size - bytesWritten);
fprintf(stderr, "Failed to write to serial device descriptor. Error: %s\n", errorString);
return result;
bytesWritten += result;
return bytesWritten;
/* Main function */
int main(int argc, char *argv[])
Settings_t MySettings;
long rxcount = 0;
long txcount = 0;
/* parse the command line arguments */
parse_args(argc, argv, &MySettings);
/* open the port */
if (openport(&MySettings) != 0) {
return -1;
/* ---- RX mode ---- */
if (MySettings.sermode == RX) {
// Reset the serial device file descriptor for blocking read / write
fcntl(MySettings.fd, F_SETFL, 0);
if (configureport(&MySettings) != 0) {
return -1;
// Begin reading
char testchar;
char expected_char = 'A';
fprintf(stderr, "Waiting for data...\n");
while (MySettings.fd > 0) {
// Wait until there is data to read or a timeout happens
struct pollfd pollOptions;
pollOptions.fd = MySettings.fd;
pollOptions.events = POLLIN;
pollOptions.revents = 0;
poll(&pollOptions, 1, 200);
ssize_t result = readBytes(MySettings.fd, &testchar, 1);
if (result != 1) {
if (errno != EWOULDBLOCK) {
fprintf(stderr, "Error reading data (%s). Exiting...\n", errorString);
break;
rxcount++;
if (testchar != expected_char) {
fprintf(stderr, "Error - unexpected value: %c, should be: %c\n", testchar, expected_char);
if (++expected_char > 'Z') {
// wrap around
// print status
if (rxcount % 1000 == 0) {
fprintf(stderr, "rx: %ld\n", rxcount);
/* ---- TX mode ---- */
if (MySettings.sermode == TX) {
fcntl(MySettings.fd, F_SETFL, O_NONBLOCK);
return -1;
// Begin writing
char testchar = 'A';
// Wait until port is writeable
pollOptions.events = POLLOUT;
// write the data
ssize_t result = writeBytes(MySettings.fd, &testchar, 1);
if (result != 1) {
fprintf(stderr, "Error writing data (%s). Exiting...\n", errorString);
break;
txcount++;
if (++testchar > 'Z') {
// wrap around
testchar = 'A';
//usleep(50);
// print status
if (txcount % 1000 == 0) {
fprintf(stderr, "tx: %ld\n", txcount);
fprintf(stderr, "ERROR- you must select a mode with -r or -t\n");
return 0;
Thanks again for your help. Please let us know if you have any questions on how to run the loopback test.
-Mark
