Set CAM0 socket MIPI port: CAM_IO1 LED Indicator/Xclk as gpio input
Dear Sir,
I want to use CAM_IO1 LED Indicator/Xclk as gpio input
How do I set pinmux ?
------------------- CAM0 socket MIPI port --------------------
Jetson Nano Camera Connector Pinout
15 Pin # 15 Pin Name ?Desc. 22 Pin Name 22 Pin #
1 GND Ground GND 1
2 CAM_D0_N MIPI Data Lane 0 Negative CAM_D0_N 2
3 CAM_D0_P MIPI Data Lane 0 Positive CAM_D0_P 3
4 GND Ground GND 4
5 CAM_D1_N MIPI Data Lane 1 Negative CAM_D1_N 5
6 CAM_D1_P MIPI Data Lane 1 Positive CAM_D1_P 6
7 GND Ground GND 7
8 CAM_CK_N MIPI Clock Lane Negative CAM_CK_N 8
9 CAM_CK_P MIPI Clock Lane Positive CAM_CK_P 9
10 GND Ground GND 16
11 CAM_IO0 Power Enable CAM_IO0 17
12 CAM_IO1 LED Indicator/Xclk CAM_IO1 18 Ground GND 19
13 CAM_SCL I2C SCL CAM_SCL 20
14 CAM_SDA I2C SDA CAM_SDA 21
15 CAM_3V3 3.3V Power Output CAM_3V3 22
Thanksk a lot.
hello andy.z,
I’m not sure which pin you’re taking about.
could you please check Pinmux spreadsheets to have pin configuration.
thanks
