I am new to Orin Nano development board. will need to use your own IMX415 camera in the project.
Need to control CAM0 PWDN, how to operate.
jetson36.6
orin Nano4G
Are you using JetPack 6.0?
You can download the pinmux from Download center (Jetson Nano Pinmux ) and see what is the GPIO ID: For example:
Jetson Nano Signal Name GPIO
CAM0_PWDN GPIO3_PS.07
Then. use the command sudo gpiofind PS.07 to get the GPIO device and offset and sudo gpioset --mode=wait gpiochip# <offset>=1 to set the value.
Manuel Leiva
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
I used jetpack6.0
Hi 56101855,
Do you want to control the following pin?
If so, please run the following commands to verify.
$ sudo su
# gpioinfo|grep "PH.06"
# gpioset --mode=wait `gpiofind "PH.06"`=0
# gpioset --mode=wait `gpiofind "PH.06"`=1
